Brake Advise
  • Thread starter Thread starter bdepedro
  • Start date Start date Oct 15, 2014
bdepedro
362
Outer Banks, NC
Oct 15, 2014
  • Oct 15, 2014
I have a '70 Sportsroof that needs help in the braking department. When I bought the car it had manual front discs and rear drums. I needed to really start on the brakes to get the car to stop at all so I upgraded to power brakes but didn't get quite the positive change in braking I was hoping for. I think that part of the problem is that my cam doesn't generate enough vacuum to power the booster. A friend of mine is running a manual brake system with a dual piston master cyl and 14" Willwood discs up front and stock drums in the rear and has great braking. I'm thinking about doing something similar but don't have the $ for Big buck brakes like that. There are a number of systems available using 11" rotors with 4 piston Kelsey Hayes calipers but they all adapt to drum spindles. I'd rather not spend $300-400 for new spindles but can't find a system that works with disc spindles. Any suggestions on how to increase braking without breaking the bank would be greatly appreciated.
Billm
48
  • Oct 16, 2014
Check out CSRP brake systems and give Dennis a call. He will be able to help you.
bdepedro
362
Outer Banks, NC
Oct 16, 2014
  • Oct 16, 2014
I had contacted them before and I need to convert my spindles to drum for all their caliper adapters which I may have to do but hate spending the extra $. Trying to keep the costs down.
Billm
48
  • Oct 17, 2014
I added a vacuum reservoir tank on my 302. It's a black can with one hose from the manifold to the can and the other to the booster. It works well. I bought it at Summit Racing with a gauge. It was reasonably priced. And the braking power is very strong. The can stores vacuum as the engine is revved up and down. This could be an inexpensive solution for making your braking system perform better.
Billm
48
  • Oct 17, 2014
The vacuum reservoir is less than 40 dollars at Summit part number G1464.
rbohm
6,698
550
204
tucson,az
Oct 17, 2014
  • Oct 17, 2014
start by making sure you have the right master cylinder. if the master cylinder is not sized properly, it will cause problems like too hard of a pedal, or too long of pedal travel.
bdepedro
362
Outer Banks, NC
Oct 28, 2014
  • Oct 28, 2014
Master cylinder came with power brake kit for a '70 so I believe it's correct. I may try a vacuum reservoir to so if I get any improvement and go from there. Still surprised that even brake upgrade kits all us drum spindles. Surely other people with stock disc brakes upgrade .
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
General karthief
