  • SN95 4.6L Mustang Tech
Brake Bedding Techniques?
  • Thread starter Thread starter SPKMustang
  • Start date Start date Mar 15, 2004
SPKMustang
87
Amherst, NY
Mar 15, 2004
  • Mar 15, 2004
Just wondering what you guys think about different bedding techniques, what works the best etc. I have read a lot of different things so I am just trying to gather a general consensus.
N
Nitrous2V
67
Conway, AR
Mar 15, 2004
  • Mar 15, 2004
I just through bleeding my brakes after putting in a line-lock and bleeding was pretty much the standard way........Start right rear, left rear, right front, left front. At times the master cylinder may need to be bled depending on what you may have installed. Bleed until the brake pedal is firm. Remember to keep a eye on the fluid level as you bleed. Hope this helps.
SPKMustang
87
Amherst, NY
Mar 15, 2004
  • Mar 15, 2004
lol not bleeding! BEDDING!! LOL thanks for the info though, im doing the install all the way around next week
DB96GT
385
AZ
Mar 15, 2004
  • Mar 15, 2004
this is what I did.
http://www.baer.com/Support/TechTips.aspx?TechTipID=5
SPKMustang
87
Amherst, NY
Mar 15, 2004
  • Mar 15, 2004
ok on there is says to never bed pads that have been seasoned, so is this to say that I can't bed my new pads on my new rotors?
DB96GT
385
AZ
Mar 15, 2004
  • Mar 15, 2004
It says to never bed pads on rotors that HAVEN'T been seasoned. Why not season the rotors? You're doing a little bedding anyway. The reason is that bedding pads will get the rotors hotter than seasoning them, and bedding them could cause the rotors to warp (if not now, sooner).
I started seasoning rotors a few years ago and haven't had any warped rotors since.
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:54 AM
keel
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
