Brake drum question
  • Thread starter Thread starter gbarber
  • Start date Start date Sep 29, 2005
gbarber
158
delaware, ohio
Sep 29, 2005
  • Sep 29, 2005
I am trying to rebuild the rear drum brakes on my '66 8-inch rear. I bought new drums at NAPA, but the center hole is too small to fit over the center of the hub on my rear axle. The hub is approximately 2 3/4" in diameter. The new drums have a center close to only 2 3/8".
The drums are 10" diameter. The shoes I took off the car were 1 3/4" wide.
Is 2 3/4" the normal size of the hub for a '66 V8 car? I don't know all of the history of this car, and I wasn't sure if maybe the rear axles had been changed at some time.
rbohm
6,698
550
204
tucson,az
Sep 29, 2005
  • Sep 29, 2005
sounds like you have later model axles. the early cars had smaller center holes. try getting a brake drum from say a 68 mustang with the same settup as your 66.
19stang66
689
  • Sep 30, 2005
I bought rear 10" brake drums for my 66 from NAPA. I have the 8" and had no problems.
gbarber
158
delaware, ohio
Sep 30, 2005
  • Sep 30, 2005
I checked with NAPA. The drums they have listed don't show the I.D. of the center hole. They ordered a different set today to see if the hole is larger. I don't know if that will work though, because I think these are for 2" brakes.
gbarber
158
delaware, ohio
Sep 30, 2005
  • Sep 30, 2005
Well, 10" X 2" brakes weren't the answer. They have the same smaller size hole.
According to NAPA's tech line, the drums that I need are probably off a '74 Maverick. They have the larger size center hole.
Now, I just realized that the previous owner must have replaced the passenger side axle with a different style axle. My driver side axle is the original 2 3/8" center, and the passenger side is the larger 2 3/4".
Should I replace the axle with the correct, smaller axle, or should I continue to use the mismatched set?
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
