brake light mod
96GRIMREAPER
21
has anyone wired up your 96+ tailights so that all six light up instead of all four. I tried splicing into the green wires and plugging into the current socket but it didnt work.......Has anyone does this..if so could you do a write up? Thanks
I don't have the color codes but you need to find the power side of each bulb connector. Once you know which they are put a diode in line with the wire you feed to the outside bulb,this will prevent "unusual" behaviour of the brake and signal systems.(both sides blinking with one signal on)
