Brake light Problems
  • Thread starter Thread starter doogie67
  • Start date Start date Sep 18, 2006
D
doogie67
69
Pennsylvania
Sep 18, 2006
  • Sep 18, 2006
When I activate my brake light switch the wire gets hot(going to the brake lights) and I hear a sizzling behind my gauges. Also my (rear)turn signals and brake lights are screwed up. Any Ideas?
Az Pete
711
18
49
Panama City, Fl.
Sep 18, 2006
  • Sep 18, 2006
Brake lights go thru the turn signals. Best get in there and start checking for a grounded hot wire or a short somewhere. Could melt down an entire harness if not fixed soon.
T
truck90278
382
Redondo Beach, CA
Sep 18, 2006
  • Sep 18, 2006
agree with Az Pere, or worse, burn the car to the ground.
C
CarlF250
59
Chicago
Sep 18, 2006
  • Sep 18, 2006
My brake lights and rear turn signals were messed up recently because I replaced the housings with reproduction units (bad idea). And one of the tabs in the socket that the light bulb touches which controls the turn signals was really flimsy and kept touching ground. Surprisingly this did not cause a short or blow a fuse like it should have, but it made my rear lights go haywire!
My instrument cluster would light up every time I hit the brakes. And if I turned the right turn signal on, both rear lights would light up as well as the instrument cluster.
I would say to check all of the ground wires and make sure everything is ok inside the light bulb sockets.
D
doogie67
69
Pennsylvania
Sep 19, 2006
  • Sep 19, 2006
You were right AZ PETE. There was a wire pinched under the turn signal switch and the mount. The previous owner just cut the wire to the brake switch to disconect the short. (It was a drag car) Thanks a bunch, you saved me a lot of time and money.
Az Pete
711
18
49
Panama City, Fl.
Sep 19, 2006
  • Sep 19, 2006
Glad to be of help and save another Mustang from a melt down. lol Nothing worse than smelling burning wires.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
