  • SN95 4.6L Mustang Tech
Brake Upgrade Question?
  • Thread starter Thread starter titanium8850
  • Start date Start date Apr 7, 2004
T
titanium8850
64
Atlanta
Apr 7, 2004
  • Apr 7, 2004
I was reading the crapper chronicle(5.0 Mustang) last night and came accross a steal on 13" brakes. I found a Bullitt 13" front set for $399.99. The contents of the package are listed here. Bullitt front 13" brake kit, includes 2 Bullitt brake calipers with mounting brackets, front brake pad set, 2 brake hoses, and 2 Brembo brake rotors.
A couple of questions as I'm interested in swapping out my front brakes with these. How hard is this to do? Do I need any other parts? What is the rear stock brake rotor diameter? 11"?
I've heard of clearance issues with 17" rims but I'm running 18x9 rims on the front and should have any issues.
I may also get the rear brake package that incudes the following:
Bullitt rear 11.65" brake kit, includes 2 Bullitt brake calipers, 2 caliper mounting brackets, 2 anti-moan brackets, rear brake pad set and 2 Brembo brake rotors also for $399.99
Any input would be greatly appreciated as I'm curious if anyone else is running this setup as an upgrade.
Black2001GT
1,267
Saints fan Stuck in FalCANTs country
Apr 7, 2004
  • Apr 7, 2004
click here
Here is a how to article.
Where did you get this deal from?
J
jphilipps
15
Minneapolis, MN
Apr 7, 2004
  • Apr 7, 2004
I just did the front of my '03 about two weeks ago and if you are mechanically inclined in any way it is REAL easy!
It took me about an 1 1/2 hours to do both sides with new hoses and all after I had the car up on stands including bleeding all the way around.
I am running 18x9's in the front and have no clearance problems at all.
I was also thinking about doing the backs but not until I am ready for a gear change. You have to pull the axles to change out the rear caliper brackets and the improvement on changing the rear is minimal so it really wouldn't be worth the work if you weren't already doing something with the rear end.
Also, if you aren't worried about the red calipers, you can buy a kit for under $200 that includes the rotors, brackets, and anti-moan brackets. All you have to do is reuse the stock calipers since they are the same anyway. The only issue would be the brake pads would either have to be replaced with cobra pads or the stock ones would have to be sufficiently worn to accomodate the wider rotor.
Here is the link http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6355
jfranci3
1,146
Indy
Apr 7, 2004
  • Apr 7, 2004
You can save $50 since you have a 99+. Get the rotors from www.tirerack.com (high quality Brembo units) $145 delivered. Then get the calipers from any Ford Motorsport dealer ($190-215 + shipping). The calipers come with pads.
J
jphilipps
15
Minneapolis, MN
Apr 7, 2004
  • Apr 7, 2004
Don't forget to factor in finding the brake hose bolts for the new calipers too if you are piecing the parts together. I hear Ford doesn't sell them without the hoses and I am pretty sure the stock GT bolts wouldn't work correctly (bigger orifice on the cobra/bullitt/mach1 bolts), but I could be wrong.
jfranci3
1,146
Indy
Apr 7, 2004
  • Apr 7, 2004
They fit fine. You don't need them on a 99+ car.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
Sponsored New J&M Release: 2024+ S650 Full Front + Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
