brand new autometer tach is junk?!?!?!
  • Thread starter Thread starter UnderdogGN
  • Start date Start date May 27, 2007
U
UnderdogGN
74
  • May 27, 2007
hey guys, just bought a brand new autometer pro comp 3.75" tach.....theres only 4 wires coming out of it....i read the directions a thousands times and it doesnt work wtf!?!?! green wire went to my MSD ignition box tach terminal, black went to the negative side of the batter, red went in to the fuse that has 12V power when the key is on, and white went to the lights. The light in the tach works fine but when i fire the car up the tach needle just sits where it has been sitting and doesnt move....anyone got any ideas or did i just waste $150 on a brand new junk autometer tach!?!?!
thanks in advance
jtfairlane
468
  • May 27, 2007
Are you 100% certain (not just making an "educated" guess) that the tach is receiving ignition hot, switched 12v?
U
UnderdogGN
74
  • May 27, 2007
im pretty sure because i put a test light where i hooked into....it lit up when the ignition was on and turned off when i turned the ignition off....ive tried it in two different spots like that
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
May 27, 2007
  • May 27, 2007
Have you tried running the signal wire straight off the coil?
HISSIN50
34
129
May 27, 2007
  • May 27, 2007
The multiple sparking will cause the tach to read incorrectly if run off the coil, but I suppose you would see that it works at all.
I'd recheck the connection on the box for the tach hook-up. Then, as mentioned, use your meter to confirm that you have 12 volts into the tach and that your ground is good (implied if you daisy-chained the ground wire for the illumination, but double check).
Good luck.
smr
167
Nor*Cal (Vacaville)
May 29, 2007
  • May 29, 2007
x2...A friend just went through three new tachs thinking he bought junk but it wound up being his msd wasnt putting out any tach signal...
MustangMatt1966
1,004
Orlando Fl.
May 29, 2007
  • May 29, 2007
ding ding ding...also check to see if the tach is switched to V8 mode..some have 4/6/8 settings i think. I cant exactly remember if that was for my shift light or for the tack...but check and make sure... I think the tach is working properly, but it is the connection to the coil that is keeping the tach from working..let us know what it turns out to be.
Matt
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
  • dan50
  • Jul 18, 2026
dan50
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Electrical - 12v on a ground wire WTF?
  • 65-Fstbk
  • Apr 26, 2023
3K
1965 - 1973 Classic Mustangs -General/Talk- Apr 27, 2023
65-Fstbk
