11sec87 Founding Member Jul 1, 2001 161 0 16 ill Nov 25, 2006 #1 Nov 25, 2006 #1 What would cause a steelgear to go south after only a few hours. I replaced the entird dist. with a new MSD unit and the gear is already showing wear after 3-4 hours. Would a HV oil pump throw too much pressure back on the dist shaft?
Anthony85stang New Member Sep 8, 2005 43 0 0 Meriden, CT Nov 26, 2006 #2 Nov 26, 2006 #2 With a hydralic roller msd says you should run a bronze gear that may be your problem.
11sec87 Founding Member Jul 1, 2001 161 0 16 ill Nov 27, 2006 #3 Nov 27, 2006 #3 If its eating a steel gear, wont it go right through a bronze gear????
