Yep...you have to remove the inner panel, then drill out the rivets from the inside, then disconnect the linkage from the inside and pull the old handle out. Install is reverse of removal, make sure you get steel handles, and like ponycar said, it's easier to use bolts. I can't remember exactly how I did it on my old Mustang, I think I used carriage head bolts but I'm not sure.
