Broken Intake bolt
  • Thread starter Thread starter COBOs69
  • Start date Start date Jun 29, 2006
C
COBOs69
  • Jun 29, 2006
Anyone know how to get a broken bolt out of the head? I have already tried and broke 2 easyouts trying to get the thing out of there. I was gonna take it to a machine shop but i thought i would ask you guys first. Maybe y'all might know some tricks.
D
D.Hearne
11,730
south louisiana
Jun 29, 2006
  • Jun 29, 2006
What heads? If the bolt screws in at a 90 degree angle, take a nut, center it over the broken bolt, fill with weld and it'll unscrew right out of the head. If it's a small block with the bolts at a 45 degree angle, you're probably better off letting the machineshop take it out.
A67StangMaster
401
San Jose CA
Jun 29, 2006
  • Jun 29, 2006
if you still got some of the bolt left out weld a nother bolt on top of it and turn. but i would take it to a machine shop just in case
1320stang
4,329
23
89
Edmond, Oklahoma
Jun 29, 2006
  • Jun 29, 2006
Is the intake still on the head? Is the head on or off the engine? What is your location? Some bigger citys have EDM machines that can burn out the offending bolt and easy-out. Costs about $20-$30 and saves the threads.
Also, if some bolt is sticking out, you could slot the end for a screwdriver if theres not enough to grip with visegrips and you don't have a welder. But before you do that, heat the bolt and head up with a propane torch and hit the edge of the hole with a candle, the wax will melt down between the threads via capillary action, let it cool and usually you can remove it with a screwdriver.
I agree with those above, welding a nut on the end of the bolt works pretty good.
xoxbxfx
3,959
Southlake, TX
Jun 29, 2006
  • Jun 29, 2006
I agree with the heat... Lots of heat. The wax tip really works, sounds funny but it works.
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
