Broken Seat Back
  • Thread starter Thread starter a68
  • Start date Start date Oct 28, 2004
A
a68
  • Oct 28, 2004
My driver's seat on my '92 mustang has broken. The seat just lays all the way back. Anyone else have this problem? What's the easy fix?
Y
yakini
28
  • Oct 28, 2004
find a used replacement. gears are probably stripped.
84blkstang
544
Springfield MO
Oct 28, 2004
  • Oct 28, 2004
i had this problem thought it was the gears well MMFF did a write up and i followed the directions on taking it apaart well the bottom was busted in 5 different places and one was all the way down the side
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 28, 2004
  • Oct 28, 2004
Find where it is laying back from, either the pivot area stripped or that actuall seat folded. This is a very common problem with foxbody seats. The frame is just barley spotwelded togeather, I had the same problem. Had the seat re-welded and it won't break now I know that much.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Oct 28, 2004
  • Oct 28, 2004
Agreed. Taking the seat apart isn't terribly difficult, though it can be a little tricky to figure out. If you run into trouble - post here, we'll help out. It may be that it's better to get a whole new seat, it may be that you can just have a quick weld job done for a few bucks -- can go either way.
J
jd351
163
Everett, WA
Oct 29, 2004
  • Oct 29, 2004
Had it happen to me, and two friends, it broke. Welding is easy and you can make it stronger while you at it.
Just take out the seat, then pull all the hardware off it that keaps the uper/lowe attached (fairly self explanitory). The hard part is the head rests. I slide a slim jim like tool in next to the head rest to disengage the lock, but it is still a PITA. Can't tell you a good way to remove, it beyond that. Then you unzip at the botom of the back piece and slowly work the back off. You'll figure it out.
Then all that is left is to weld it or get it welded. While you at it, weld all the seams and add a couple of straps where it broke. The factory only spot welds the two shell halfs together and this makes them flimsy, leading to cracks and un-firm seating.
Then all thats left is getting it back together, its difficult, but if you take your time it will work. In the end you will have a more rigid seat than you did before, makes you think your car launches harder.
shttygtstang
978
  • Oct 29, 2004
easyest cheapest fix through a milk crate behind the seat
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
