5% Discount Offer - Online or In Store - Enter TAKE5 in the coupon Code at Checkout
Brothers Performance Table Top Special Blow Out List
Save Hundreds of Dollars While Stocks last - This Week Only!
See Something you want to buy - GIVE US A CALL 800-486-2681
Engine Components
SCAT SBF 302 CAST CRANK 3.400 28OZ $176.72
SCAT SBF 302 4340 H 5.400-2.123-.927 $305.24
SCAT 331 CAST/I-BEAM/SRP-FLAT R/A $791.00
SCAT 331 FORGED/I-BEAM/KB-FLAT R/A $955.00
CANTON 96-04 MUSTANG 4.6L ACCUSUMP INSTALL KIT $112.00
CANTON 3 QUART CANTON ACCUSUMP $148.00
CANTON OIL COOLER KIT 86-95 5.0L MUSTANG $235.20
COMP CAMS TITANIUM KEEPERS/RETAINERS $37.44
COMP CAMS 5.0 274/282--.555-.565 CAM $216.83
COMP HI-TECH ROLLER RACE SET $52.40
COMP MAGNUM TIMING CHAIN SET $28.77
PRO COMP GIRDLE MAIN 351W $59.76
PRO COMP 302 main girdle w/hardware $31.20
PRO COMP GIRDLE MAIN 400 CHEVY $65.15
PRO COMP 350 CHEVY MAIN GIRDLE 50.70
PRO COMP SBC DUAL PLANE INTAKE MANIFOLD $61.75
PRO COMP DISTRIBUTOR - TFI FOX BODY 5.0L MUSTANG $95.00
PROBE 4.6 RINGS .020 OVER $90.99
PROBE ROD FORGED CNC I BEAM 4.6L $180.00
PROBE PISTON FLAT TOP 4.6L (8EA) $334.24
PROBE ROCKER STUD GIRDLE 7/16 $78.75
PROBE 4.6 18.1CC DISHED PISTONS $341.99
FORD RACING CRANKSHAFT 4.6L CAST $156.21
Transmissions
PERFORMANCE AUTOMATIC TRANSMISSION 87-93 MUS AOD $1,299.99
PERFORMANCE AUTOMATIC 93 1/2 UP MUS TRANSMISSION AODE COMP $2,199.99
PERFORMANCE AUTOMATIC 93-95 MUS TRANSMISSION AODE $1,399.99
PERFORMANCE AUTOMATIC 98-02 MUS TRANSMISSION AODE 4.6L $1,499.99
PERFORMANCE AUTOMATIC 96-97 MUS TRANSMISSION AODE 4.6L $1,429.99
PERFORMANCE AUTOMATIC 05-08 MUS TRANS PAN KIT AUTO-ALUM $299.99
PERFORMANCE AUTOMATIC BELLHOUSING C4 PRO-FIT $299.99
PERFORMANCE AUTOMATIC FLEXPLATE SFI 4.6L MUS 8 BOLT $68.99
PERFORMANCE AUTOMATIC FLEXPLATE SFI 50 OZ 164 TOOTH $60.00
Programmers &Tuners
SUPERCHIPS GM CORTEX $289.99
SUPERCHIPS 99-08 GM LS1,2,4,6 FLASHPAQ $259.99
SUPERCHIPS FORD CORTEX $289.99
SUPERCHIPS 05-09 MUSTANG FLASHPAQ $259.99
SUPERCHIPS 99-08 FORD TRUCK FLASHPAQ $259.99
SUPERCHIPS 08 FORD 6.4L DIESEL FLASHPAQ $259.99
SUPERCHIPS 99-07 FORD DIESEL FLASHPAQ $259.99
