buckin problem
  • Thread starter Thread starter blue87lx
  • Start date Start date Mar 24, 2006
blue87lx
175
  • Mar 24, 2006
i recently put an offroad h on my car and now when im at a steady speed it feels like my car bucks/has a small miss. i checked all plugs wires and stuff. now the tube that comes from the hpie and connects in the engine bay i left disconnected. wouldl this have anything to do with it?
M
my289eatsrice
121
Woodstock, CT
Mar 24, 2006
  • Mar 24, 2006
Yes, this is your EGR. You must connect this, especially if you need to pass emissions. This will control your idol at lower rpms up till 3/4 throttle, so at WOT, then it wont have any effect. See if you can reconnect this tube, and then you won't have any problems.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2006
  • Mar 24, 2006
This isn't the EGR. It is the Thermactor Air System or smog pump. It blows air into the cat converters to make them work. If you don't have cats, it is pretty useless.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
Hving done my best to enlighten others, now for help in finding & fixing your problem.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
JBeezy53
559
Sacramento, Ca
Mar 24, 2006
  • Mar 24, 2006
I used heater hose as the tube from my x-pipe to my check valve.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • brandyn200
  • Jun 20, 2026
AeroCoupe
