Bucking at part throttle
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
I have an 89 GT with an F cam, full exhaust and full MSD ignition, other than that its pretty much stock...At lower rpms (under 3000) when I try to cruise at part throttle the car starts bucking and hesitating, just wondering what could cause this.....BTW my brake booster is shot and leaking I dont know if that would have anything to do with it
Could be the cam duration if you are running a 5-speed or you could be runing rich or you could have the tps set to high for the idle speed that you are runing. See if you set your idle speed low and your tps high you are going to have problems.For example when i installed the cam in my gt i had an idle speed of 800 rpm and the tps was set at 0.97 and when i drove it the it was bucking at cruise. But when i lower the tps to 0.82 and adjusted the idle to 900 rpm it was fine.You don't really need to turn the tps up high to get good throttle response because the computer will adjust and you will have good throttle response at 0.82 and less bucking.Try it good luck.
Possibly, or you have a wiring problem, or problem with the computer. Try just testing the black wire of the TPS to a ground. See what the voltage reads. May also want to try and run the Key on, engine off codes also.
