  • 1994 - 1995 Specific Tech
Bucking under load when warm
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Jul 28, 2007
OrangeMustangGt
1,976
Cape Cod, MA
Jul 28, 2007
  • Jul 28, 2007
My last resort is to see if anyone on here has the same issue. For the last month this has been getting progressively worse. when my car is hot, and i give it gas it bucks real badly.
I have cleaned my new MAF, and run codes. All i got was a 02 sensor rich on left side, so i replaced it....no help.
Anyone have ANY ideas?
BlackVert
5,589
9
98
Bethesda, MD
Jul 28, 2007
  • Jul 28, 2007
i had a very similar symptom. it was worn out spark plug wires, one was loose and got flakier as the engine warmed up
mine was more like a miss with hesitation, i wouldn't have described it as bucking though
blksn955.o
3,263
st.louis mo 314
Jul 28, 2007
  • Jul 28, 2007
Dont you have a tweecer/SCT?
I know you took off your ter-bo's but what else are you running now cam and such?
I had a bucking issue from when I first installed my non-ported gt40's, TFS1 cam, and ported lower gt intake. I added 24's but ran a C&L as I didnt have a tweecer yet. Had a bucking at around 1,700-2,500 rpm or so IIRC.
Went with the tweecer and stock maf along with a cobra base file and 0 issues. I now run a 98gt maf and had a VERY VERY VERY slight bucking at like 2,000-2,200 in like 4th on the hwy. I didnt even really notice it and thankfully I did notice it when I ran a datalog...I actually thought it was the wind since it was windy out. EA suggested a VERY VERY VERY small change in the MAF transfer in that exact area...now its gone too.
Methodical
1,192
11
59
Clinton, MD
Jul 28, 2007
  • Jul 28, 2007
Did EA suggest you to richen or lean the MAF curve? I had a similar issue but realized I had not done any DLs after having the lower intake ported and EA had me richen up many areas on MAF.
mustang1994bob
25
oklahoma
Jul 28, 2007
  • Jul 28, 2007
Its almost definatly plug wires!! I had the same problem chased it and chased it, the bad part was I had just done some rearend work and so I almost paid someone to "fix" the problem in the rearend. Remember always start with the simple stuff, to check them just go out to the car in the middle of the night with all the lights out, and just start it up and look under the hood you can spot the leaks right away, also look for spots that the spark might like to jump to, like the engine lift eye, then when you replace them make sure to avoid those kind of things and use wire looms
F
Fopar
178
San Marcos, CA
Jul 28, 2007
  • Jul 28, 2007
plugs here too, 1 was cracked 2 were loose...
OrangeMustangGt
1,976
Cape Cod, MA
Jul 29, 2007
  • Jul 29, 2007
Thanks guys, I will look at my plugs/wires.
Its not a tuning issue, although I still have some light mods the car was running flawlessly for a while after i removed the PITA turbos. I like how it drove like a stocker....untill now.
You have a good point.....Even at WOT it still has the bucking issue...and I thought i heard a bit of detonation, which it never had....possibly wires cross firing. I just put these Ford Racing Blue plug wires on a few months ago....so if there dead Im gonna be pissed. They LOOK to be in great shape, and I put High temp boots around the plug ends at the heads.....
blksn955.o
3,263
st.louis mo 314
Jul 29, 2007
  • Jul 29, 2007
Honestly, I get confused on that part...all the criss cross of numbers meaning opposite things...I made a note on Tweecer on my laptop to keep it straight but that is in the backseat.
My K's were like .93-.87 in the erea of the transfer that was suggested be changed, I moved the graph ever so slightly to the right on the transfer...
zenboy99
2,212
Madison, WI
Jul 29, 2007
  • Jul 29, 2007
One thing to check.... ACT versus ECT, our stock EEC will richen the mixture up when the ACT gets above 120. I had driveability issues in the heat that were fixed by changing this value in my Tweecer.
mustang1994bob
25
oklahoma
Jul 30, 2007
#10
  • Jul 30, 2007
  • #10
turbo?? im in the mood for a PITA, do you still have the set up??
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Jul 31, 2007
#11
  • Jul 31, 2007
  • #11
i had an issue like that a while back...got the Sensor and Relay package from 50resto...i actuall think the 02s fixed it because it cleared right up after theie install...
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M12071K302 1&comp=LRS
gcomfx.com
3,690
Republic, MO
Jul 31, 2007
#12
  • Jul 31, 2007
  • #12
Dang... that's a pretty good deal. Usually O2s are about $50 shipped. It's almost like getting all the other sensors free.
OrangeMustangGt
1,976
Cape Cod, MA
Aug 1, 2007
#13
  • Aug 1, 2007
  • #13
I still have the turbo setup. Really All I need to do is to install V-bands instead of the clamps i was using. I may put it back on someday
OrangeMustangGt
1,976
Cape Cod, MA
Aug 2, 2007
#14
  • Aug 2, 2007
  • #14
I FIXED THE PROBLEM!!!
today the drive to work was sooo nice.
It was a plug wire shorting to my headers, I reversed the wire so the short 90 deg end is at the head....it clears the long tube opposed to the 45 deg on my fms plug wires that were melted and sparking. It dident do it cold, so i drove the car untill hot at night, and opened the hood with it running and misted the engine with water.....then I saw the arcing.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Aug 2, 2007
#15
  • Aug 2, 2007
  • #15
Good deal on fixing it, now sell me your front bumper
BlackVert
5,589
9
98
Bethesda, MD
Aug 3, 2007
#16
  • Aug 3, 2007
  • #16
plug wires ... it took me almost 6 months and lots of money in unnecessarily replaced parts to find mine. man was i stupid about it. oh well, live and learn.
i'm glad you're good to go! :SNSign:
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
