ok guys, this is the last weekend the track is open until Feb. during the winter i'm thinking about beefing up my drivetrain, focusing on the rear end. I just got a set of DR's and dont want to have to worry about snapping an axle or screwing something up at the track, bc its my DD and dont want to be left high and dry. i know im not putting down much more power than stock, but the mods will continue and i like having peace of mind.
this is what I'm thinking:
Moser/FRPP 31 Splines
FRPP/Eaton/Auburn/Detroit Locker Differential
FRPP aluminum driveshaft
McLeod Clutch
all new bearings and seals
FRPP 4.10s (which i already have installed)
my questions are:
which brand differential do you all recommend?
same question about the 31 splines? are the FRPP's just as strong as the Mosers?
Would it just make more sense going with FRPP all around (differential/axles/gears)? or is there anything wrong going with say, the Moser axles and one of the above mentioned differentials?
I also plan on doing Kooks or SLP LT's sometime after the new clutch is installed for a little more giddy-up, and probably some MM LCA's to help me hook. i'm also looking into springs. i know the stock springs are pretty good for weight transfer (right) but i gotta get rid of that 4x4 look. i have a set of new H&R sport's in my closet, but im afraid they will hurt my launches. What about FRPP "B" or "C" springs? which will give me a better look but still offer decent weight transfer? i dont know much about spring rates and what they mean. then probably some tokico 5-ways all around. im expecting tom to chime in on this one.
i know its a lot of questions, but i appreciate all the help. thanks
McLeod Clutch
my questions are:
