What was everything you did for your Bullitt intake swap.What ever you had changed out from the stock to the Bullitt conversion,they will need.
For someone doing the Bullitt intake swap properly,they will need as a kit if you have these things as they are Bullitt intake specific....
-altenator
-6G to 4G Conversion Plug #462802D for the altenator (paperformance.com)
-altenator bracket
-throttle cable
-cruise cable (But not really needed unless they want to keep cruise)
-throttle cable/cruise cable bracket
-inlet tube
-throttle body
-fuel rails (Standard GT fuel rails will not work)
-the coolant tube that runs under the intake is specific to the Bullitt,but one can modify the stock one
-'01 to '04 t stat housing for proper fitting as it face away from the altenator
-EGR tube (but one can run a delete plate)
Hope this helps.
