Burning alternators!??
  • Thread starter Thread starter hillie16
  • Start date Start date Dec 14, 2009
hillie16
9
108
Dec 14, 2009
  • Dec 14, 2009
This is actually about the 5.0 in my truck, but I'm hoping someone can help. The alternator went bad in my truck, and I've had to replace it 3 times since in 3 months. The voltage regulator is new with each alternator. What could be causing it to burn up repeatedly? The battery is old but I've had it tested 3 times and they said the battery was fine. Any ideas?
HISSIN50
34
129
Dec 14, 2009
  • Dec 14, 2009
Are you using a 2G or 3G?
Are the alt's coming from the parts store? If so, there might be nothing wrong with your ride. The stuff from parts stores can be quite lackluster, with crap components inside.......
Do you know how the alternators are failing? What kind of voltage do you see? Does it stay at around 15V or will it drop down to the 13.5 range once it's been run for a bit?
As long as your charge cable is not dropping a lot of voltage (which makes the alt kick up the output and can cause it to run warm) and the belt tension is proper, you really should not be frying them.
If you feel like testing your wiring for some reason, the regulator is lableled ASI.
A = battery voltage.
S = Stator. It floats about 1/2 battery voltage while the car runs.
I = Ignition turn-on. This shows nominal voltage while the car is running.
Good luck.
hillie16
9
108
Dec 14, 2009
  • Dec 14, 2009
The first 2 replacements were remans, the third is new. I need to do some testing....
95Vert383AOD
1,133
34
69
New Bedford, MA
Dec 14, 2009
  • Dec 14, 2009
Don't run the vehicle without the battery connected. Figured i cover that....I know alot of folks that will pull the power cable off the Battery to see if the Alt works.....Also don't let your Alt. Charge a dead battery....Make sure the battery has been trickle charged and can start a vehicle on its own.
Figured ide cover some basics "just incase"
Chris
Oh yeah...i had a situation where alternators kept dieing on me...(swapped threw 3-4) Then i went and got one from a junk yard (Funny aint it) Its been fine ever since!!!!
9
9050lx
33
  • Dec 14, 2009
I would also check fusible links or just run a new wire.Make sure connections are tight, grounds are good....
T
THOR74
72
Ontario, Canada
Dec 15, 2009
  • Dec 15, 2009
Your "old battery" concerns me...I've seen batteries that have passed the "test" and yet ended being dogs that had no real stamina and ended perpetually putting a heavy load on the alt and wrecking it. Maybe it's time for a new battery...
Also, I have seen people buy the cut rate "reman" alts and literally go through up to 4 of them in a matter of weeks until buying a higher quality product.
Since your truck ran before, this is where I would start - new battery and higher quality alt. This is easy and, in any event, your money will not be wasted (and we're not talking big bucks here).
If these initial basics don't solve it, then dig deeper.
Good luck!
HISSIN50
34
129
Dec 15, 2009
  • Dec 15, 2009
Maybe or maybe not. I've not had much luck with parts store stuff. The components don't often hold up to stress or heat. Just something to remember if your wiring looks sound.
If you had a big wiring issue (or something that was erroneously frying alts), it should show itself a lot sooner than a couple months into a new alt.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Dec 19, 2009
  • Dec 19, 2009
Like mentioned battery might be checkign good, but could be taking charge liek it should and over working alt..
I did the 3g swap in my 94 f-150.. Nothing worng with stock ALT just needed more juice when I put the amp, electric fan and fog lights on. didnt cost me anything though, since I had an extra 3g alt and mustang alt bracket laying around. There is a direct swap one, from a "E" series van but cant remeber what year exactly, but do remeber the alt was costly, so thats why I ude stang parts..
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
M
12 mustang gt check charging battery light
  • millerj7950$
  • Jan 24, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 14, 2026
BossHorseGirl
