  • SN95 4.6L Mustang Tech
burning oil?
  • Thread starter Thread starter 00GTpony
  • Start date Start date Aug 24, 2007
00GTpony
162
  • Aug 24, 2007
I feel liek my car is burning oil.. I changed my oil 2 weeks ago, and only 4 quarts came out of the motor when 5 was put in. Thoguth i waited 5000 miles before i changed it 2 weeks ago. I just checked my oil tn, and its a tad low. How could this be, its def not leaking from filter, or drain plug. I drive the car really really hard, and someone told me that could be why. ANy ideas?
Killa
1,006
56
49
Aug 24, 2007
  • Aug 24, 2007
How many miles is in your car, when ever I feel my car burning oil, I just swap it to castrol high mile.
00GTpony
162
  • Aug 24, 2007
Killa
1,006
56
49
Aug 24, 2007
  • Aug 24, 2007
00GTpony said:
76,000
Switch to valvolin max life or castrol gtx high miles let see if its help, it does help me though.
RandyStinchcomb
1,159
Randallstown, Md
Aug 24, 2007
  • Aug 24, 2007
the use of 1 qt of oil per 1000 miles of driving is NOT considered a problem, asper FoMoCo.
if your still troubled by this, when was the last time you changed your PCV valve? it should be changed at 30k intervals under normal driving
G
GettinThere
553
Central Texas
Aug 24, 2007
  • Aug 24, 2007
RandyStinchcomb said:
...when was the last time you changed your PCV valve? it should be changed at 30k intervals under normal driving
10-4 Lately I noticed oil on the passenger side valve cover. I replaced the pcv valve a few weeks ago and, problem solved. I have 44k miles.
Btw, when I went to my local Ford parts counter to get a Motorcraft pcv valve, I also needed the black plastic elbow that attaches to the top of the pcv valve. Instead of the $20 "hose assembly" (that has said elbow), the parts guy found the elbow by itself as a Cobra part.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
