buying intake hae questions on stuff???
ok im getting the holley systemmax intake
i know i need to get a sn95 adapter summit has ones made for a 75mm throttle body there by trick flow but it says its for trick flow intakes
will it work with the holley if not where can i get one that will
also
do i need a egr plate i see they sell them for 87-93
i dont know what that does so if someone could elaberate that would be great
thanks
dan
94-95 does not use an egr plate. 94-95 egr hangs off the back of elbow. As for the elbow, I used an edelbrock elbow for my edelbrock intake. I believe they are all the same. The purpose of the elbow is to join the intake to throttle. 86-93 and 94-95 uses the same size opening at face of intake and back of throttle. So I see no reason why trick flow wouldnt work for systemax.
Here are a few links that you can use other then trickflow.
http://cgi.ebay.com/ebaymotors/ws/e...ategory=42604&item=7985835922&sspagename=WDVW
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=38634&item=7985092621
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=38634&item=7985990615
im goin with a dss short block
306 long rod 9.1 compression
afr185cc heads
holley systemax intake
#30 injectors
75mm throtle body
80mm mass air
tfs stage 2 cam
1.6rockers
msd ingintion
your is very similier thats y i asked. i cant wait its not goin to be till feb or march
when i get back but im goin to order the stuff while in in iraq that way when im home i can slap it together. hopefully it will rip.
i think its goin to be a pretty good combo
i went with 9.1 comp becuase later i would like to add nitrous or a supercharger
later
dan
