C-4 knocking noise
  • Thread starter Thread starter MScott65
  • Start date Start date Feb 15, 2004
M
MScott65
Phoenix
Feb 15, 2004
  • Feb 15, 2004
Hi,
I am beginning to restore a 1965 Mustang. The C-4 transmission has a knocking, chattering noise whenever the brake is applied. Only in Park and Neutral does the noise go away. Any helps as to where to start and what to do?
Thanks
10secgoal
2,801
San Diego
Feb 16, 2004
  • Feb 16, 2004
Are you POSITIVE it's coming from you tranny ? Does it do it when you drive, then hit the brakes.. need more info. It's more than likely not your tranny though. Or your brakes are just distracting you from the actual trigger.
M
mp67
392
Texas
Feb 16, 2004
  • Feb 16, 2004
Need a little more info please. When you say when the brake is applied, do you mean when you are shifting from park into reverse or drive? Or do you mean when you are driving? If it is while you are shifting from park into a gear, then thats when you are putting a load on the tranny, and could be the pump, converter or hard parts in tranny. If its not a constant noise, then it could be u-joints. If its when you are driving and you brake, it is most likely not the tranny. Hard to make a diagnosis like that without experiencing, so your best bet is to probably let a tranny shop mechanic test drive. Be careful though, I was in that buisness many years ago, and there are some shady people there. Get a shop with references from people you trust. Try this. Hold foot on brake in park and shift into gear and note any noise. Then drive and brake several times at different speeds noting exact noises at each time. Post back results and hopefully someone can steer you in right direction. Good luck on your resto, the first one is always the most fun.
M
MScott65
Phoenix
Feb 16, 2004
  • Feb 16, 2004
Thanks for your reply. The shuttering, clattering noise happens when I am shifting from Park to reverse or drive with the brake pedal pressed. Currently I have the car on blocks. If I have it in drive and then apply the brakes the noise begins and stays as long as the brakes are applied even though the wheels are no longer spinning.
Scott
M
MScott65
Phoenix
Feb 16, 2004
  • Feb 16, 2004
Scott
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
K
351w engine swap
  • Killer351w
  • Jan 21, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 21, 2026
Killer351w
K
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
