Good morning,
I am building an 87 LX Fastback with a 427 suf engine and will be using a Pro shift Toploader 4 speed transmission. I have wilwood clutch and brake pedal assembly and need help with some dimensions for the installation? I will be using a hydraulic clutch setup as well. If anyone has any experience with this installation I would very appreciate any information you can share? One question is, how many inches would the bottom of the pedals need to be off the floor board? Also, will this setup work with a stock mustang steering column?
Thank you
427stang
Thank you
427stang
