  • SN95 4.6L Mustang Tech
C and L
  • Thread starter Thread starter shifty4.6
  • Start date Start date Feb 17, 2004
shifty4.6
71
  • Feb 17, 2004
I just purchased the c & l plenum and 75 mm throttle body. I have an 02 gt. I dont have anyone to change my chip, will i loose power if dont calibrate my chip? If any one has done this please tell me what gains or lose's i should expect. I have all the bolt ons dont to my car.
gruntman31
624
Colorado Springs, Co
Feb 17, 2004
  • Feb 17, 2004
You shouldn't need to change your chip. You would only need to if you went to a bigger MAF meter. If you've got all the bolt ons I would go get a custom dyno tune, you'll pick up a good amount of power from it. If you live anywhere near Mooresville, NC you HAVE to go Modular Madness Motorsports. Don is a dyno tuning genius.
8yourZ06
128
  • Feb 17, 2004
If you have nothin but basic bolt ons..the intake plenum and throttle body will only give you about 5 to 10hp ..different heads or adding boost is where you see the most gains from that upgrade.
Beau
3,050
San Diego
Feb 17, 2004
  • Feb 17, 2004
you don't have to change anything after you put those on. just disconnect your batter, tap the brake a few times to clear any electricity out of the circuit, and wait 10 minutes or so. then reconnect the battery and fire it up.
StangLou
1,264
Holly Springs, NC
Feb 17, 2004
  • Feb 17, 2004
Off topic, but Gruntman, where you at in NC?
On topic, you shouldnt need a tune unless you really have "all" the bolt ons. These being, full exhuast, bigger tb and new plenum, gears, pullies, ect... If you havent done a full exhuast or added a new tb/plenum combo, then you wont see much out of a tune. the only thing you need to worry about is that your c&l is calibrated to match your fuel injectors
shifty4.6
71
  • Feb 17, 2004
If i diconnect my battery with my chip in will it erase my chip's settings or will i be ok?????
shifty4.6
71
  • Feb 17, 2004
I have ALL THE BOLT ONS. How would i get the C & L to match my injectors?
Beau
3,050
San Diego
Feb 17, 2004
  • Feb 17, 2004
i don't think so, your chip's settings are burned in, so all you are doing is basically ensuring no current flows through the chip for 10 minutes or so...when you re-attach the battery and start the car, power will once again flow through the chip, except the car will know be reading new information due to the increased airflow from the parts you added.
wms004
2,864
Los Angeles
Feb 17, 2004
  • Feb 17, 2004
when i installed my plenum i disconnected the positive and negative.. is it necessary to disconnect both? I'm going to install a 75mm t/b soon
JonJon
4,801
back in Marylands
Feb 17, 2004
#10
  • Feb 17, 2004
  • #10
just 1
and hold the brake down for like 20 seconds to drain the power left in the system
then everything is reset properly
8yourZ06
128
#11
  • Feb 17, 2004
  • #11
there is no need to reprogram anything...you dont need to worry about the fuel injectors unless your go with a different mass air flow sensor that is calibrated for larger injectors..
StangLou
1,264
Holly Springs, NC
Feb 17, 2004
#12
  • Feb 17, 2004
  • #12
when you ordered your mass air meter, they should have asked you how you want it calibrated... for 19lb, 24lb, 32lb, ect... injectors. If you got a mass air meter that wasnt properly calibrated for your injectors then it will wreck havoc on your a/f and give you a horrible idle/run condition.
gruntman31
624
Feb 17, 2004
#13
  • Feb 17, 2004
  • #13
Salisbury. About 45 minutes north of Charlotte.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
  • Mindseye007
  • Aug 16, 2026
Mindseye007
