c&l 80mm
  • Thread starter Thread starter coupecop
  • Start date Start date Aug 18, 2006
C
coupecop
166
mission texas
Aug 18, 2006
  • Aug 18, 2006
i just whant to know what i can do to fix with the problem withmy c&l the car turns on find and runs find in low speed but notice that when i hit the gas hard it tends to hesitat a little.
daddystang
185
  • Aug 19, 2006
I'm not sure, but mine does the same thing a little. I've got the C&L 76mm w/ the 24lb injector tube. It hesitated pretty bad until I bumped the fuel pressure up to 47lbs. Now it's pretty good, but still does it just a little. Still needs tweeking I guess. Try bumping the fuel pressure. All depends on what mods you have too. Hope that helps a little.
L
luckythirteen13
648
Anaheim, CA
Aug 19, 2006
  • Aug 19, 2006
this is a common issue with C&L because it uses the stock electronics in a larger maf housing. try clocking the maf to get better/correct air flow
vristang
4,933
101
124
Seattle
Aug 20, 2006
  • Aug 20, 2006
47 psi is too high, and can cause some other fuel metering issues in the low rpm/load ranges.
I suggest sticking with the stock of ~40.
If clocking the maf works, great.
I would look in other places for the cause though.
jason
  • Mindseye007
  • Aug 16, 2026
Mindseye007
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
