- Apr 26, 2004
- 11
- 0
- 0
Already posted on the corral, but since then I am not able to post any more meesages?? Seems weird, but here is my problem again:
Car will idle for a few seconds then die,,,then restart and it dies, over and over. Almost like a vacuum leak, cause you have to give it gas to keep it running. Once you are on the road driving it is fine, until you come to a stop or put it in neutral, in which case it dies again.
So, bought a new IAC thinking that was the problem,,,helped for like a day, then right back to where it was,,,dying over and over.
So, swapped out the stock TB/plenum and problem solved! Runs great, doesn't die any more. Now, just need to figure out which one is the culprit. Maybe it's the TPS?? The openings on the plenum seem to match perfectly with those on the stock plenum...so....I don't know...
I am not sure what to make of it, so any ideas are appreciated.
