C & L: thoughts and a question
  • Thread starter Thread starter mrswivlepants
  • Start date Start date May 23, 2005
First Prev 2 of 2
I
Insane3D
310
#21
  • May 25, 2005
  • #21
Rick 91GT said:
I found better results with a stock box and regular cheap paper filter worked best..
Tried the cone K&N and the K&N panels as well...neither worked as good.
I just went back to the stock airbox with K&N with my 73mm and it works like a charm. It was what Lee suggested. I haven't tried a normal paper filter, but I'm not sure why it would make any difference....the air path would be the same.
Also, for the CAI guys, the stock airbox is a CAI...they take the air from the same place.
87mustang347
82
#22
  • May 25, 2005
  • #22
damnit!!! that sux cause i dont have the stock airbox. a buddy of mine has the c&l and hes using the long filter and not an air box and he says that it works perfect. i think its a 73mm tho. whats up with that?
FiveLtrRiceEatr
197
Michigan
May 25, 2005
#23
  • May 25, 2005
  • #23
correct, but I forget to mention the fenderwell CAI's, they all do the samething though.
I'm not sure why his works. I didnt have a stock box either, I bought one off ebay for a $1
theres 2 on ebay right now, but more than I paid.
one for 9.99
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=34198&item=4551268941&rd=1&ssPageName=WDVW
one for 13.00
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=38634&item=7975657598&rd=1&ssPageName=WDVW
hope this helps
87mustang347
82
#24
  • May 25, 2005
  • #24
well i dont have paypal nore do i no how to use ebay. who wants to by it for me?
87mustang347
82
#25
  • May 27, 2005
  • #25
i went to go look at my friends car today and hes not running a bog filter like i thought he was. hes using that moroso cold air kit and is using the c&l pipe and he says it works fine. didnt u guys say that the mafs dont work good with the cold air kits?
W
WLDHRSE
701
Elkton, MD
May 28, 2005
#26
  • May 28, 2005
  • #26
92BlackGT said:
i have a 73mm one. Never had a problem. Yes it uses the stock sensor.
You posted a question of why your car is so slow. I responded a little bit ago saying that this meter may be your problem.
On my 93 GT (1st sig pic) I had a 76mm C&L along with the rest of the usual bolt-ons minus H&C. The car ran great but was slow. After thinking about swapping it for a year, I realized that I had a Pro-M 75mm MAM in the basement. I swapped them and was amazed at the difference. I gained what I knew I was missing instantly. I have not tried it but a lot of people say if you have one that does not work good that you can rotate it 90 degrees to get the sensor sitting differently in the airflow.
Cliff
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
May 28, 2005
#27
  • May 28, 2005
  • #27
I have a 76 MM one on my 306, i converted the car over to mass air with this meter and used taurus electronics on top. no complaints at all from me
Venom351R
4,548
41
98
MAINE
May 28, 2005
#28
  • May 28, 2005
  • #28
I currently have a C&L 76 MM but I bought a PRO-M 80 MM today. Im going for a dyno tune on the 13th, Im going to see if I can do 2 seprate pulls one w/ the C&L and one w/ the PRO-M. Id like to see the diffrence in the #'s. If the tunners will let me do this Im going to try it, my computer will prob be thinking WTF!!! is going on but it would be an interesting experiment.
87mustang347
82
#29
  • May 28, 2005
  • #29
hey that would be cool. post up the resultsd asa u can
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
May 28, 2005
#30
  • May 28, 2005
  • #30
waht i have found is the people who have problems with c&l are the 4.6 mustnags or guys with forced induction. all the complaints i read before i bought mine were mainly those cars
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
May 28, 2005
#31
  • May 28, 2005
  • #31
C&L's suck, i've seen it first hand many times.
If you want to chance running lean on a powerful engine that you have alot of money into go ahead it's your car.
You won't see most of the guy that run low 12's and faster using them. There's a reason for that.
Of course before everyone blows up about this, there is exceptions to the rule, and some cars actually run good with them. But they are inconsistant meters, meaning some cars run good, some don't. A pro m calibrated right always runs right there is no maybe about it.
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
May 28, 2005
#32
  • May 28, 2005
  • #32
i'm gonna disagree here, check my garage for my mods and with that setup i went to get a dyno tune and i was running very close to perfect air/fuel ratio and all i did was set my fuel psi at 40 psi. but of course with a dyno tune he played around with my fuel psi and found me more power
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
May 29, 2005
#33
  • May 29, 2005
  • #33
What did your car dyno at?
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
May 29, 2005
#34
  • May 29, 2005
  • #34
i had ignition problems and could only pull it to 4800 rpm, but on a mustang dyno it made 261@4800, the guy said once i get my ignition sorted out i will see 300RWHP on his mustang dyno. i don't know hwat those numbers work out to on a dynojet
and no it wasn't my mass air meter that was holding me back
Bobert
63
#35
  • May 29, 2005
  • #35
I must have got the "non suck" model since I never hurt anything with 600+ hp on a stock block with cheap ole Fel Pro's HG's (1101's or whatever they're called)....even while detonating the thing like a dumbass a few times
Now my buddy used the same meter on practically an identical setup and blew HG's....but I think he didn't have enough fuel pump....or I was very lucky.
First Prev 2 of 2
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
