C4 fluid capicity?
  • Thread starter Thread starter Chris89LX
  • Start date Start date Aug 7, 2004
C
Chris89LX
1,375
Calgary, Canada. THE TRUE NORTH STRONG AND F
Aug 7, 2004
  • Aug 7, 2004
What is the approximate fluid capacity of a C4 trans with a Moroso aluminum pan and tranny cooler.
90NotchBack
306
Loxahatchee/Pembroke Pines, FL
Aug 7, 2004
  • Aug 7, 2004
I think 6 or 7 because I'm C6 with a deep TCI pan holds 6 or 7. I don't remember excatly. Just put like 4 1/2 quarts start it up and then check it and put it in as needed.
maverick0716
3,924
Chilliwack, BC, Canada
Aug 7, 2004
  • Aug 7, 2004
Is that filling the torque converter as well?
hllon4whls
BANNED
2,567
Covington
Aug 7, 2004
  • Aug 7, 2004
A C6 holds more than that. I just put 8 quarts in mine after losing some from dropping it and I am still low. I did drain the converter when I did it, but still I was shocked. I figured on gallon would do it, but 2 did not even fill it.
hllon4whls
BANNED
2,567
Covington
Aug 7, 2004
  • Aug 7, 2004
To the original post, buy a case of fluid and a funnel that would work. Better to have a little left over than not have enough.
90NotchBack
306
Aug 7, 2004
  • Aug 7, 2004
I just drained the pan and i put 6 or 7 quarts back it. I converter was already filled. When i do oil changes or change the trans fluid i just buy a case.
C
Chris89LX
1,375
Aug 8, 2004
  • Aug 8, 2004
The reason I ask is because I put in five quarts and started it up to ckeck the fluid. It was low so I added another two quarts and shifted it through the gears but had no out put yet. I added another half quart and I had out put from the trans but it still showed slightly low on the dipstick. That's when I tried to add another half quart and it started coming out the dipstick tube. And now it shows way full.
So at a total of nine quarts it came out the dipstick tube.
That was with a completely dry converter and cooler. But it does include me puting one quart into the converter on install.
G
gopher_6_9
55
  • Aug 8, 2004
With a completely dry trans you will use about 10 quarts...... where is it coming out the dipstick tube? it should not leak anywhere if it is comoing out it would have to be at the top and there is no way it is that full.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
W
Dipstick
  • wccurtis1963
  • Jun 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
Willybill32
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
