C4 Problem
  • Thread starter Thread starter bnav8or
  • Start date Start date Apr 10, 2016
bnav8or
  • Apr 10, 2016
Decided to try a master rebuild on my C4 from my 65 coupe with the 6 cylinder 200. Rebuild went great or so I thought. There are no leaks and forward gears go forward and reverse goes backward. Problem is it stays in gear in park or neutral. Did I screw something up or could it be simple like band adjustment.
tos
896
68
59
Cincinnati Ohio
Apr 11, 2016
  • Apr 11, 2016
Sounds like your linkage adjustment is off a little. You will get a lot of different procedures to adjust it properely and this trans is easy to adjust improperly. What I would try is put your shifter lever in neutral, jack the rear wheels off the ground or put on a lift and put the trans lever in neutral and verify by rotating back wheels and watching drive shaft to confirm its actually in neutral. You can then insert a drill bit thru the neutral safety/reverse switch and thru the shift linkage to line it up. you may have to loosen the switch bolts a little to fine tune.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
2010 V8 4.6 5 speed won't go into gear while running
  • Back road driver
  • Dec 30, 2024
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jan 30, 2025
89ripper
