Ok so as I was down shifting into 3rd to make a turn I heard a decently loud pow/pop and lost the ability to shift into any gear. Few days later I dropped the transmission to find out the clutch shattered into many many pieces, very old clutch as it was anyways.
So I put a brand new clutch kit, slave cylinder in and put it all back together. Cranked up the car with no issue until I tried to go into any gear, it just won't it's like they are all locked out. If the car is off it'll go into all the garages with ease. After reading online it seems my problem could just be a faulty slave cylinder. So a lot of head scratching, hair pulling and vacuum bleeding the hydraulic clutch with still no progress I decided to drop the transmission again and put in a brand new better made slave cylinder, bench bled and all that.
I decided to test it after getting the transmission and shifter back into place before attaching the drive shaft and while running went into each gear like butter, so finished putting the car back together and now it won't go into any gear again, if I put it into gear 1st and try to crank the car it wants to jump forward but won't turn over.
Is there something I may have missed? Is it possible to put a clutch in backwards and it cause the symptoms I'm having? I've been fighting with it for a couple months now and desperately need to get it back on the road so any advice or thoughts will be greatly appreciated.
