c4 shift points
  • Thread starter Thread starter enferno
  • Start date Start date Nov 18, 2006
enferno
418
  • Nov 18, 2006
on the vacuum modulator . .do i turn the screw clockwise or counterclockwise to lower the rpm at which the tranny shifts?
thanks!
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Nov 18, 2006
  • Nov 18, 2006
thanks!
I believe that you back it out CCW to decrease the rpm.
Irregardless, it is very easy to figure out since it is a very course adjustment. Back the screw out 2 full turns and take it for a test drive--be sure to put the hose back on or else it will act like it will never shift. If we went in the wrong direction, then turn it CW 4 turns (which overshoots where you began.) Fine tune from there.
GoinBroke
109
Joliet, Il
Nov 18, 2006
  • Nov 18, 2006
Dennis is right as always. CW lengthens the shift point to a higher RPM and CCW retards it. Just had to do this a couple weeks ago on my new tranny.
enferno
418
  • Nov 18, 2006
thanks!
19stang66
689
  • Nov 19, 2006
So what is a good shift point for a c4? Is it personal preference or is there a performance aspect too?
C
C0V3R
524
Australia
Nov 19, 2006
  • Nov 19, 2006
Would a leaking hose explain my c4 never wanting to shift up at WOT? I need to back right off after a WOT burst in order for it to shift up.
dennis112
1,561
36
79
Nov 19, 2006
  • Nov 19, 2006
Yes, a leaking/missing hose or a bad modulator will delay an upshift until you leave off the gas (or nearly hit redline.)
dennis112
1,561
36
79
Nov 19, 2006
  • Nov 19, 2006
Yes, a leaking/missing hose or a bad modulator "might" delay an upshift until you leave off the gas (or nearly hit redline.)
Of course you could have valve body issues too, but the modulator stuff is the easiest to mess with.
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
