C4 trans help needed
  • Thread starter Thread starter CPH89LX
  • Start date Start date Apr 26, 2026
C
CPH89LX
Syracuse, IN
Apr 26, 2026
  • Apr 26, 2026
So I'm working on my 89 fox body that has a 347 stroker with a c4 trans down in it. I had a leak on the trans where the kick down cable hooked into the side so I replaced that seal in there. Now here comes my problem. I got everything put back together and fluid back in it, only problem now is that after I filled the trans back up I do not have reverse. I have park and all forward gears but when I put it into reverse, the tires still spin forward. I have drained everything and made sure I got the valve body reinstalled correctly and it's still doing the same thing. Curious if anybody has any ideas to try before I throw it on a trailer and take it into a shop to be fixed? Previous owner told it had reverse valve body and high stall converter in it but didn't figure anything would change by just fixing the shift shaft seal leak. All fluid looked good and not burnt. Any ideas would be a big help.
Thanks.
General karthief
Mod Dude
Aug 25, 2016
28,099
10,713
213
polk county florida
Apr 27, 2026
  • Apr 27, 2026
Have neutral?
C
CPH89LX
Syracuse, IN
Apr 28, 2026
  • Apr 28, 2026
Yes I believe i do. Had the wife shifting it for me while I was under the car spinning the drive shaft. You could feel it lock up when in park, have drag on it when in reverse, then go freely when in neutral, then back to having drag when going into drive.
It's suppose to have a reverse valve body in it. Could that be part of the problem?
General karthief
Mod Dude
Aug 25, 2016
28,099
10,713
213
polk county florida
Apr 28, 2026
  • Apr 28, 2026
Using the stock shifter?
Did you have the engine running when doing the test?
C
CPH89LX
Syracuse, IN
Apr 28, 2026
  • Apr 28, 2026
It is using an older B&M shifter. I have went and adjusted the cable to make sure it's hitting each gear as I'm shifting it. Getting same results motor running and not running.
General karthief
Mod Dude
Aug 25, 2016
28,099
10,713
213
polk county florida
Apr 28, 2026
  • Apr 28, 2026
I would guess, if the only thing that was removed was valve body and the shift link that maybe the shift link is in the wrong place like sticking a distributor one tooth off? Is that possible I'd have to consult my book to see if it even covers it.
Just for clarity, you have Park, can't roll vehicle, reverse wheels spin forward, Neutral and three forward gears right?
C
CPH89LX
Syracuse, IN
Apr 28, 2026
  • Apr 28, 2026
Yup that is exactly what I have right now. Gonna open it back up tomorrow night and just go over everything once more. Hopefully like you said I just have the shifter off somehow in there where it meets up with the shift rail.
Reactions: General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 9:15 PM
AlexM556
A
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
