C4 Trans Question
  • Thread starter Thread starter cronics66
  • Start date Start date Jul 14, 2006
C
cronics66
  • Jul 14, 2006
Hello to all fellow mustang owners and fanatics. I am new to this forum, and I have a question about my 66 GT Stang. I recently cracked my bellhousing on my old C4 tranny. I was able to find a used, but working condition C4 transmission. I put it on and fired her up and a I came across a high pitched rattle right under the bellhousing. I was thinking that I might not have properly engaged the torque converter properly. My question is, how many steps does the converter have to drop before it is engaged fully? Im hoping this is the problem, does anybody else have any suggestions on what else it could be? Thanks for the help.
eagleautosports
139
Mebane NC
Jul 14, 2006
  • Jul 14, 2006
It should take about 2 or 3 thunks but the last one will be a real solid sound. I doubt if that's it though because if it wasn't properly seated, everything wouldn't have bolted up right so I'd say check all bolts and make sure they're tight before taking it back out just yet.
302 coupe
1,952
Macon, Ga.
Jul 14, 2006
  • Jul 14, 2006
just take the bellhousing off of the replacement trans and put it on the original trans, since it sounds like the original was working properly.
C
cronics66
  • Jul 14, 2006
I can't reuse the old trans, it has a shot brg in the tail. This would cause a serious vibration and also clunks when put into reverse or even drive. Driveshaft, u-joints and rearend all re-done, before moving into the tranny. Come to find out the tail shaft spline was way to loose, might have caused the bellhousing to break.
C
cronics66
  • Jul 14, 2006
Im going to look into that, I was actually thinking it could have been the starter, but it makes the noise even when its running, so I crossed that out right away. Thanks though!
A67StangMaster
401
San Jose CA
Jul 14, 2006
  • Jul 14, 2006
ITs 3 clicks i just did this recently.
C
cronics66
  • Jul 14, 2006
Thanks, I'm going to look into other things before actually trying to take the tranny off again.
D
D.Hearne
11,730
south louisiana
Jul 14, 2006
  • Jul 14, 2006
If you jammed it together, I'd bet you've now busted the front pump gear too. Also check to see if the crank counterweight isn't rubbing on the block plate.
Capt Dan
237
College Station, Texas
Jul 14, 2006
  • Jul 14, 2006
make sure the starter is disengaging.
302 coupe
1,952
Macon, Ga.
Jul 14, 2006
#10
  • Jul 14, 2006
  • #10
Also, if the torque converter has a drain plug, make sure its sticking through the cut out in the flexplate.
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
G
66’ drum bleeding
  • Geno66
  • Sep 1, 2025
Classic Mustang Specific Tech Sep 8, 2025
GOvert
G
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
