cai and tuner problem
Make sure you check the Gear Ratio and the Revolutions/Mile that are set-up in the Optional Parameters on the Tuner. For proper revs/mile you can go to your tire manufacturer website and find your tire size and find the proper revs/mile. If your tires/gear ratio are different than what's programmed, this could be giving you incorrect calculations for your gas mileage. Check those items first and if you have no luck, contact Brenspeed and they should be able to help you out, as they have great customer service.
