  • 1994 - 1995 Specific Tech
CAI for 93 TB conversions.
  • Thread starter Thread starter 95Vert
  • Start date Start date Apr 17, 2006
95Vert
1,785
North Mexico (deep south Texas)
Apr 17, 2006
  • Apr 17, 2006
Can you guys post pics? I'm waiting for the delete plate and will be making a cai, but I need to know what size couplings you guys used on the TB. Also, what size hole you drilled for the sensor in the tubing(one with red thing in the middle).
Thanks
9
95mustang_gt
364
Wisconsin
Apr 17, 2006
  • Apr 17, 2006
do you have a cai now? well i just cut my mac cai and added a 86-93 c&l tube and that was it.
here are some pics if you want to see
http://pg.photos.yahoo.com/ph/mustangcobra0495/detail?.dir=e43c&.dnm=58d0scd.jpg&.src=ph
http://pg.photos.yahoo.com/ph/musta...=&.done=http://photos.yahoo.com/ph//my_photos
jesse
95Vert
1,785
Apr 18, 2006
  • Apr 18, 2006
I don't have one. I just want to use a straight pipe and avoid as many bends as possible. I want my only bend to be at the TB.
18mustangs
533
Virginia Beach, VA
Apr 18, 2006
  • Apr 18, 2006
Thanks
I modified my SN95 CAI and used a Fox C&L pipe.
RIO5.0
6,892
N.H.
Apr 18, 2006
  • Apr 18, 2006
The 93 Cobra is kinda tough due to the added 2" lenght in the intake snout...Getting by the shock tower is hard....I tried coming out on a 45 deg tube off the TB and still needed to sweep around the tower...The CL kinda makes the turn nicely...
I swapped to a GT40 and making a SS CAI for that...a 45 DEG sweep right off the TB work's with it as its shorter than the Cobra...
There are place that make 8" long or so 45deg silicone turbo hoses, you could try that right from the TB...its got some flexablity to it...
You can see the rub on the shock tower....Use a 5/8" dia hole for the IAT sensor and you can just thread the sensor in....I drilled a hole and used a rubber gromet for the oil vent..
I used a 45 deg sweep to get into the fender...You want straight so just add to the CL???
My Pro77 was on the end in the fender...
95Vert
1,785
Apr 19, 2006
  • Apr 19, 2006
Thanks Andy. After taking to redsnk95, I plan on keeping a short pipe. I'll get that 45* you said and about 6-8" of piping, enough for the IAT and since I have a breather cap, I won't use the vent hose.
Thanks
Y
yellowclone
68
  • Apr 19, 2006
I used the CAI that I already had and just turned it and added a 45*, 3" drain pipe from lowes. It doen't look the best in the world but it serves the purpose for now.
http://www.stangsource.com/forums/attachments.cgi?id=1115
http://www.stangsource.com/forums/attachments.cgi?id=1116
Sorry about the quality, I took the pics with my phone.
Andy
95Vert
1,785
Apr 20, 2006
  • Apr 20, 2006
YellowClone, it didn't let me see the pics.
Andy(rio) How in the world did you get your intake to look so smooth. Did you sand it, and how much?
Y
yellowclone
68
  • Apr 20, 2006
Lets see if this works.
95Vert
1,785
Apr 20, 2006
#10
  • Apr 20, 2006
  • #10
It worked, but I'm trying to avoid the 90* bend. I think i'm using a 45* with about 8" of tube to make it work.
Thanks
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 20, 2006
#11
  • Apr 20, 2006
  • #11
How you gonna do that
The fox setup requires you to first clear the shock tower.
Unless you go with another bend of some kind .......
You end up pointing straight at the front of the car as your pipe parallels
the shock tower.
Without another bend, you can't get inside the fender
Grady
RIO5.0
6,892
N.H.
Apr 20, 2006
#12
  • Apr 20, 2006
  • #12
Lots of sanding.....I shot it with hi-build primer then went at it...Guide coat and start wetsanding....Did that a few times over til it was mint...Shot it with sealer,then PPG Concept...a single stage Urethane, color and clear combined so to say...Never touched it afterwards...Stuffs tha ball's..
Sanding/prep is what makes a paint job...
Check these guys...I just got some stuff here...a 45 deg silicone hose is prolly your best bet??
http://www.racepartsolutions.com/categories.asp?cat=90
95Vert
1,785
Apr 20, 2006
#13
  • Apr 20, 2006
  • #13
Thanks Andy, I'll look into that.
Grady, I've seen people on here that run just a 45* bend at the TB and shoot it straight to the fenderwell. They have to cut the hole bigger because it won't line up properly, but it has been done. Let me see if I can find some pics.
95Vert
1,785
Apr 20, 2006
#14
  • Apr 20, 2006
  • #14
Check it out Grady. Oh, and I don't have the STB anyway.
But my intentions were to make it short like this one. He says he tried it out and the one that gave the most power was the one with a shorter pipe.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 20, 2006
#15
  • Apr 20, 2006
  • #15
I see in the pic it was done
Glad you put it up
Bends hurt airflow ... no doubt about it.
Convoluted pipe is also nasty about slowing airflow btw.
By the pic, that pipe looks to be huge. I think I see a reducer at the maf. The pipe size is most likely 4"
Got a feeling, this next bit of info is not gonna be well received but I'm gonna say it anyway
IMHO, a stock block NA typical street combo is not gonna flow enough air that a 4" pipe is a must have kinda thing.
If you go down in pipe size, that may help you in your attempt with rigging up a cai of some sort.
Speaking of bends
How is that bend any different than the 45 sn elbow and a straight shot to the fender hole
Grady
Y
yellowclone
68
#16
  • Apr 20, 2006
  • #16
Thanks
I'm also using a 45* angle and with my 94-95 CAI it lined up perfect on the throttle body and other pipe.
RIO5.0
6,892
N.H.
Apr 20, 2006
#17
  • Apr 20, 2006
  • #17
I been dubbing around coming up with something for mine...trying to keep the turn subtle by the TB....I had hot start probs long ago with MAF in the bay so I wanna keep it stuffed it in the fender....MAF's on the end..
still have to cut 2" or so more out of the fender to line thing's up...It's a start anyway....
95Vert
1,785
Apr 21, 2006
#18
  • Apr 21, 2006
  • #18
That's going to be cool Andy. I know a guy with a muffler shop whom can probably custom bend a 3"(thanks Grady) pipe to go directly from the TB to the fenderwell. Might go that route.
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
J
New to Mustangs/Fords
  • Joradan93Foxbody
  • Mar 2, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 2, 2026
Joradan93Foxbody
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
