CAI or RAI
  • Thread starter Thread starter ktaylOR2012
  • Start date Start date Oct 8, 2011
ktaylOR2012
256
stl.Mo
Oct 8, 2011
  • Oct 8, 2011
is there much of a difference with the hp with a bama programer CAI 8-15 hp how much does a RAI add?
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Oct 8, 2011
  • Oct 8, 2011
KN air filter, remove the air box and call it a day.
Maxpowers
859
Pittsburgh, Pa
Oct 9, 2011
  • Oct 9, 2011
Agreed. Not worth the money.
It's short ram intake or SRI.
BurningRubber
1,865
24
58
Oct 10, 2011
  • Oct 10, 2011
Ram air does nothing for these cars except funnel dirt into your filter. The Mach-1 setup is the only really good setup you'll get on a Mustang.
Stumbaugh
903
Russellville, Ar
Oct 10, 2011
  • Oct 10, 2011
Is there anyone on here that has a stock intake set up with just a K&N insert? I ask because I am curious what your IAT's are. Jerry and I did some data logging in Myrtle Beach of his JLT RAI vs my JLT CAI just to see the difference. My IAT's stayed on average 25 degree's colder than his at every speed.
I actually was data logging my car on the way home tonight (for nitrous), and my IAT's were staying at 50 degree's, and it's 67 degree's here.
BurningRubber
1,865
24
58
Oct 10, 2011
  • Oct 10, 2011
That's interesting that yours stays cooler than his. Where does his pick up the air from? If it's way down low, on a hot day it's going to suck up the hot air radiating off the pavement. Yours obviously from the fenderwell.
Somewhat related... K&N's "heat shield" doesn't do **** for the FIPK intake except block 1/3rd of the filter.
Stumbaugh
903
Russellville, Ar
Oct 10, 2011
  • Oct 10, 2011
The JLT RAI picks up the same place as your FIPK.
duzy
80
jacksonville fl
Oct 11, 2011
  • Oct 11, 2011
i dont know about ram airs all i know is I got a CAI and it was a waste of money spend the money on like gears or something, then just put the remander money into a spectra air filter and take off the air box and your good. should come out the be the same amount of money
03_TrueBlue_GT
810
41
29
Houston, Tx
Oct 11, 2011
  • Oct 11, 2011
I used to have a BBK CAI but felt that it was causing more bad than good so I switched it to the stock intake that you described and got some $ for the BBK piece. I haven't had a chance to see what the IAT's are but I will post them when I get a chance.
Stumbaugh
903
Russellville, Ar
Oct 12, 2011
#10
  • Oct 12, 2011
  • #10
When I first bought my 02, it had a BBK cai on it. I honest to goodness could tell a difference going from the BBK to the JLT.
But yes if you dont care to, find out what the temperature is outside and get some IAT readings. I am curious to see what they are.
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
Oct 12, 2011
#11
  • Oct 12, 2011
  • #11
FWIW, I have a stock air intake with a K&N filter and a removed silencer.
On a cool night, at highway speeds, I pull IATs that are just slightly above the outside air temperature. For example, the other night when it was 37 degrees as the low, my IATs were between 37-41 at 70 mph. At highway speeds, the IATs are usually ~ 1-5 degrees higher than the outside temperature. Sometimes less, sometimes abit more. I wish I had "stock" numbers to compare to. Anyone?
J
4 bank eliminator chip
  • JJ's90fox
  • Feb 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
