- Sep 5, 2004
- 78
- 0
- 0
help me pick a cam... i know a custom is the best choice, but i'm gunna do a custom cam when i put the car on the bottle. Right now i just need one to get it started
stock block 347
Forged Eagle Crank
Forged Scat Rods
DSS racing pro-lite pistons
Completely Balanced (28oz) and Blue Printed
10:1 compression ratio
Ported Dart heads (unsure of the flow numbers but i bought them from a friend who went 6.0s in the 1/8 with a 357 on nitrous)
Edelbock RPM II intake
80mm mass air meter
30lbs injectors
75mm trottle body
3.90 gears
So far my main choices are:
Anderson N-41
Comp Cams XE282HR
Comp Cams XE274HR
stock block 347
Forged Eagle Crank
Forged Scat Rods
80mm mass air meter
30lbs injectors
75mm trottle body
3.90 gears
Anderson N-41
Comp Cams XE282HR
Comp Cams XE274HR
