Cam owners I need help!
  • Thread starter Thread starter MAC'n89Blckstng
  • Start date Start date May 31, 2005
MAC'n89Blckstng
1,012
NJ
May 31, 2005
  • May 31, 2005
I have a fresh rebuilt motor with higher compression and an E303 cam. Ever since I put the new motor in the car surges like a mofo. When I first start the car will idle with a real nice lope and sounds awesome but after I drive her for a while she will not hold a steady idle. I tried unplugging the IAC and bumping up the idle screw but it still surges. I also have about 8 month old 02 sensors in it as well. What could be the problem? Oh yea it didn't have any idle problems before I put the new motor in. Its really startin to get on my nerves so any help is greatly appreciated.
Thanks,
Jesse
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
May 31, 2005
  • May 31, 2005
jesse,
your going to find that this is a very common problem. you could try cleaning and/or replacing some of your sensors to help it.
MAC'n89Blckstng
1,012
NJ
May 31, 2005
  • May 31, 2005
Does anybody think its a TPS problem?
stang22
1,318
Washington, D.C.
May 31, 2005
  • May 31, 2005
What is the voltage range from idle to WOT? It should be between .99 and 4.50 volts. Pulled any codes? The TFI could be on it's way out the door as well. There are a number of different things it could be, you will just have to run everything out one by one.
Tim
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
May 31, 2005
  • May 31, 2005
clean your maf with electrical contact cleaner, clean out the IAC with carb cleaner, check the TPS voltage, should be about .98 with the key on motor off
also i had this problem with my new motor (see garage for mods), i did the above and it went away and i thought it was perfect till i went and got a dyno tune, that really cleaned up the idle
87MustangGT5.0
153
Maryland
May 31, 2005
  • May 31, 2005
Wont these kind of things happen if you replace the cam in a speed density car? Although I know that is not the case with an 89....just wondering.
90LX306
433
Warren, R.I.
May 31, 2005
  • May 31, 2005
want kind of maf u using? i had a c&L and the car ran like ass w/my cam, switched to pro-m and it fixed my problems. later
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
May 31, 2005
  • May 31, 2005
If it still surges with the idle solenoid disconnected, I'd say you've got a wicked vacuum leak somewhere.
MAC'n89Blckstng
1,012
NJ
Jun 1, 2005
  • Jun 1, 2005
I checked all my vacuum connections plus its not constant, sometimes it will idle fine other times it willl surge. Im gonna try cleanin the mass air today hopefully that helps. It's been buggin the hell outta me. BTW Im runnin a stock mass air.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
