Cam pin.
  • Thread starter Thread starter Dbeck002
  • Start date Start date Aug 27, 2005
Dbeck002
710
South florida
Aug 27, 2005
  • Aug 27, 2005
I installed a short cam pin in my cam (the one that locks the gear to the cam) and my shop says it would be a better idea to use the long one. I hear that the long one is too long though and material has to be shaved off to be flush with the cam gear.
Anyway its too late, i tapped the short one in but i had an idea. I cut a section of the large pin and inserted it into the hole where the pin goes into the cam gear. My shop says this is a good idea to keep the short pin from walking out. Since the washer covers half of the pin face and I torqued it down pretty nicely, do you think i did the right thing? Has anyone used the short cam pin and encountered any problems?
rd
3,316
63
109
Ocean Springs MS
Aug 27, 2005
  • Aug 27, 2005
I guess that will work.
The short pin is meant to allow space for the locating tab on the two piece fuel pump eccentric. I have always replaced them with the long pin and single piece fuel pump drives on my carbed cars.
04sleeper
2,674
14
89
Dallas, TX
Aug 27, 2005
  • Aug 27, 2005
I would pull it out and replace it with the long pin.
I know several people who have tried the short pin only to have it shear off.
txstang84
1,639
42
69
Tuscola, tx
Aug 28, 2005
  • Aug 28, 2005
Dbeck002
710
South florida
Aug 28, 2005
  • Aug 28, 2005
Well it doesnt matter how long the pin is, the shear force is dependant on the cross section. even if it was a nub that was an 1/8" long it was still take the same amount to shear.. see what i mean. Im just worried it will walk out thats all. Thanks for the replies guys this helps a lot.
04sleeper
2,674
14
89
Dallas, TX
Aug 28, 2005
  • Aug 28, 2005
Not really. I have seen it first hand and will NEVER run one like that.
Sorry.
Dbeck002
710
South florida
Aug 28, 2005
  • Aug 28, 2005
What im saying is this, the stock cam has a short pin (that is hollow mind you) and it held up for 15 years. i installed the short pin on the new cam (which is solid), the only problem i see with it is walking its way out of the cam. I put extra material infront of the pin with the other pin (box came with 2, long and short so i cut some material from the other pin and used it like a stopper) and tightened the washer down, my shop said this is ok and would work better than filling the hole up with sealant. i hope this makes things clearer, its hard to explain.
04sleeper
2,674
14
89
Dallas, TX
Aug 28, 2005
  • Aug 28, 2005
OK. I got you now.
Dbeck002
710
South florida
Aug 28, 2005
  • Aug 28, 2005
haha good..
maverick0716
3,924
Chilliwack, BC, Canada
Aug 28, 2005
#10
  • Aug 28, 2005
  • #10
I tried the long pin with my Comp Cam......too long! I couldn't get it out either, so I had to cut it and file the edges so they're slightly rounded. It was a pain in the ass, but it worked good.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Ecc pin out #4
  • 5.0buggy
  • Feb 24, 2025
  • Other Auto Tech
Other Auto Tech Mar 14, 2025
89ripper
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
