Cam Question
  • Thread starter Thread starter boozie73
  • Start date Start date Sep 27, 2005
boozie73
Oueens, N.Y.
Sep 27, 2005
  • Sep 27, 2005
I was thinking of using an FMS X303 cam for my 92 GT. w/TKO500. What heads? Wanna use AFR 185's with flat top pistons. Is this cam gonna combo well with these? Standard bore 302 cid.
I
IntenseBlue
946
  • Sep 27, 2005
Should work very well together providing you have a gear and a good intake.
Rick 91GT
Mustang Master
95
99
PA
Sep 28, 2005
  • Sep 28, 2005
Are you using an aftermarket flat top piston? The X cam will not clear a stock piston with the AFR, personally depending on the rest of the combo the X cam may not be the best choice..
boozie73
Oueens, N.Y.
Oct 2, 2005
  • Oct 2, 2005
I'm using Summit speed pro forged flat top pistons w/four valve reliefs. supposed to be 10.8 to 1 w/52 cc heads. I'm using a tremec tko 500 and got 3.73 gears in the rear.
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
R
New heads
  • Robman8028
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2025
gkomo
