  • 1994 - 1995 Specific Tech
cam question
  • Thread starter Thread starter Cobra51807
  • Start date Start date Jun 4, 2009
C
Cobra51807
20
  • Jun 4, 2009
i wanna go with the f 303 cam i have a 94 cobra with cold air intake short headers and off road hpipe and the factory gt40 heads and intake what cam would work good for my ap would you say. and what do you think about the f 303 and what els would i have to do to use the cam or would it be ok the way it is besides a tune. thanks
Adam95GT
2,564
Burlington, NJ
Jun 4, 2009
  • Jun 4, 2009
you should tune no matter what... popular cam choices are
TFS 1
Steeda 19
E 303
earleys94gt
1,223
Ashley, Ohio
Jun 4, 2009
  • Jun 4, 2009
I had the Steeda 19, and it wasn't too bad.
The cam is really designed for superhcargers, so the low end lacks power a little. But, if you had a supercharger it would make up for that.
Once you hit about 3000 RPM, you could really feel the car pull hard to redline.
Another good aspect was the car idled like stock, even without a tune. Though, like Adam said you should get a tune.
The E303 or Trick Flow stage 1 seem to be good all around choices. Any issues they cause could easily be fixed with a tune.
Another, more expensive, option woudl be to get a custom cam made.
Ultimately, it's a personal choice...do some research and you'll find one.
ProKiller
3,064
15
78
PA
Jun 4, 2009
  • Jun 4, 2009
the e303 and the f303 are like cousins. the f is just a little bit more aggressive. its actually a decent blower cam too. just make sure if you're using your stock 1.7 rrs you check your valve lift.
A
Airfuel2000
  • Jun 19, 2009
I dont understand, why anyone would use these outdated cams, e,b,f,x 303 are garbage. There is more tech in the new cams today. Example- the Trickflow 1 is a redesigned E-303 cam, and the XE270hr is taking one step further...I run the xe270hr and have zero complaints whatsoever.
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
1994 - 1995 Specific Tech May 29, 2025
General karthief
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
