  • 1994 - 1995 Specific Tech
Cam Questions
  • Thread starter Thread starter 5.0snake
  • Start date Start date Aug 3, 2005
5.0snake
95
South Eastern PA
Aug 3, 2005
  • Aug 3, 2005
How much is a typical cam swap cost?
GRGT1994
1,034
  • Aug 3, 2005
I'm guessing you mean for the labor to have someone else install it. This is just a guess, but it's probably gonna be like 4 to 8 hours. So it could get pricy.
But call some shops and your dealer. Ask them how many hours they would estimate.
Cobra4075
286
Tinley Park, IL
Aug 3, 2005
  • Aug 3, 2005
It's not too difficult to do it your self. If you go that far, I'd change the lifters and the timing chain as well.
I
igotyofire
774
Southern California
Aug 4, 2005
  • Aug 4, 2005
im not sure but im going to guess around $400, i think my shop will do it a lil cheaper then that for me
I
igotyofire
774
Southern California
Aug 4, 2005
  • Aug 4, 2005
how long are lifters good for
mootang
907
texas
Aug 4, 2005
  • Aug 4, 2005
roller lifters will last for a long time but most people just replace them since it's cheap insurance for later.
GRGT1994
1,034
  • Aug 4, 2005
And once you're in there it's real easy to swap them. If you find yourself breaking the motor down later just for lifters, you might be ticked.
That said, I didn't change mine. They all looked new after 90,000 miles.
5.0snake
95
South Eastern PA
Aug 19, 2005
  • Aug 19, 2005
I was thinking of getting the TFS Stg1 cam and then buying the heads later on and then a 1.5 KB maybe is in the works possibly? Dont know
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 20, 2005
  • Aug 20, 2005
that cam worked great on my combo. i didnt have any surging stalling or idle problems at all. even with the 112lsa, the car also held good vacuum under all conditions. best part is, the cam is dirt cheap.
GRGT1994
1,034
#10
  • Aug 20, 2005
  • #10
If you are thinking Kenne Bell down the road, then pick your cam based on that. The TFS is a great cam from what I hear, but I think it is primarily designed as a NA cam for use with Twisted Wedge heads. So just make sure you do plenty of research on cams for the KB.
BTW, if you do the cam, then the heads, you will probably want to do your intake next, cause that will be your bottle neck. Then you will want to do you TB, injectors, MAF, fuel pump/FPR, headers. All those parts build off the others.
So maybe you want to think about just starting with the KB, and call it good?
Y
Dash cam
  • yankeyfan02
  • Sep 15, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 18, 2026
horse sence
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
J
Cam for 1989 2.3 4 plug
  • Jaycee1964
  • Dec 12, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Dec 14, 2025
AeroCoupe
