Cam questions...
  • Thread starter Thread starter 87_stang
  • Start date Start date Jan 16, 2006
87_stang
131
Tonganoxie, KS
Jan 16, 2006
  • Jan 16, 2006
I am switching my 87GT over to carb setup and had a few cam Q's. I was looking through summit and was looking at the summit cam kits. They are hydraulic cams and lifters and I believe the 87 mustangs came with roller cam. Correct? What is the difference between these and performance difference? I havent really messed with hydraulic cams before and not sure what they are all about. Second, is the distributor gear different on these? Do the points distributors and non-points distributors use the same gears? Sorry for all the questions, I know they might be stupid but my mind just went blank in the cam section! Thanks in advance fellas!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 17, 2006
  • Jan 17, 2006
ok you do not want to go to a hydraulic flat tappet cam from a roller hydralic cam. good news you can now run more cam then your computer controller (MAPS) 302 would have liked since you will be going carb'd.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 17, 2006
  • Jan 17, 2006
First off -- the stock roller cams/lifters in the HO's (like your 87) ARE hydraulic cams. You can have solid rollers or hydraulic rollers; solid flat tappet or hydraulic flat tappet. Solid cams (rollers or flat tappets) require some means of setting valve lash (adjustable rockers). You don't have to worry about that with the hydraulic lifters and your roller cam.
You do need to check on gear compatibility though. You'll have to switch distributors if you want to have some mechanical advance capability with the carb motor. Check to be sure the distributor gear on the replacement distributor you use is compatible with your cam choice. The cam and distributor manufacturer's can help you with that. Also, I wouldn't go with a points-type distributor. There a plenty of options that use a magnetic pickup instead of points -- much more reliable and accurate.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
