Hi All,
I'm new to the forum (first post). I'm looking for good resources (any type) to help me prep for a supercharger setup on my 91 Fox GT. The car is not stock. Below is the current build. Looking for any advice anyone is willing to give. Thanks in advance!
Block: 427 ford performance short block, part # M-6009-427F
Heads: Ford Performance Z-head aluminum assembled cylinder head: part # FMS-M6049Z304DA
Head Gasket: Ford Performance Parts Performance Cylinder Head Gaskets, Part # FMS-M-6051-R351
Rocker Arms: Scorpion Race series rocker arms 1.65 Pontiac 7/16, Part # SCC-SCP1053
Lifters: Lunati Street performance retro-fit hydraulic roller lifters
Intake: Edelbrock 351 EFI Super Victor
Fuel Injection: Holley HP ECU for multi-Port EFI
Fuel Injectors: Holley 66 lb/hr
Fuel Rails: Edelbrock
Fuel Pump: Holley 255 LPH in tank pump
Fuel Regulator: Holley billet fuel regulator
Distributor: MSD
Transmission: Tremec TKO 5 speed
Cam: COMP Cams Xtreme Energy Retrofit D288/294, L0.555/0.576
Timing set: COMP Cams magnum double roller timing set
Driveshaft: ford racing 3.5 inch aluminum
Flywheel: Ford racing SFI neutral balance flywheel, Part# M6375-D302B
Alternator: 75 Amp NAPA brand
Radiator: Frostbite 4 core
Water Pump: Hi-flow
Fans: Perma-Cool 12.5 inch x2 (rated at 2300 cfm each)
Engine Oil: 10-30
Oil Filter: Motorcraft FLA1
AC: Sanden
Air Filter: K&N racing filter
Oil Pan: Ford Performance, part # FMS-M6675DRS351
Oil Pump Pickup: Ford Performance, part # FMS-M6622DRS351
Oil Pump: Melling High Volume, Part # MEL-M83HV
Headers: BBK shorty
Pulley Set: BBK
Exhaust: MAC, No Cats, Full 3 inch with X-pipe
Distributor: MSD
Water Pump: Hi-flow
Engine Oil: 10-30
AC: Sanden
Headers: BBK shorty
Pulley Set: BBK
