  • SN95 4.6L Mustang Tech
CAM ?'s
  • Thread starter Thread starter bboylobo
  • Start date Start date Jul 25, 2008
bboylobo
130
Lancaster PA
Jul 25, 2008
  • Jul 25, 2008
Ok i got my 01 v8 and i was reading around about cams. What is PI and what should i be thinking about before i decide if i want to put new cams in my engine. I dont know anything about them other than what they do. Maybe someone can point me towards a Tut. Thanks a bunch
Wolvrin704
120
Milford, OH
Jul 25, 2008
  • Jul 25, 2008
PI=power improved
PI is 1999+ so with a 2001 GT you already have PI. Putting in aftermarket cams can increase your horsepower 30-40 hp from what I've been reading. But I'm not sure if thats true for the stage 1 as it is with the stage 2. If the stage 1 can make close to that increase that will be the route I go as well.
mogs01gt
3,113
30
119
Ohio
Jul 25, 2008
  • Jul 25, 2008
Do all bolt on first then worry about Cams.
Stark77
501
Tallahassee, FL
Jul 25, 2008
  • Jul 25, 2008
Stage 1's with valve springs (compcams) can add around 20rwhp from what I've heard if the tuning is done right. The cost to HP ratio is fairly pricey. Also gas mileage will drop a bit. Cams are most effective when done with an aftermarket intake manifold like the typhoon or P-51 AND even more effective with new set of heads.
bboylobo
130
Lancaster PA
Jul 25, 2008
  • Jul 25, 2008
What are some good bolt ons to start with for power. i already got CAI.
Stark77
501
Tallahassee, FL
Jul 25, 2008
  • Jul 25, 2008
Most CAI's aren't too useful for worthwhile power increases. I've tried MAC, and K&N CAI set ups and am currently using JLT True Cold Air. Biggest improvement/noticeable gains out of all three. Underdrive Pulleys from Steeda, a midpipe, rear gears, and a tuner are the best things you can do.
bboylobo
130
Lancaster PA
Jul 25, 2008
  • Jul 25, 2008
not to sound like a noob (i am though whats a midpipe. What are some things i can do with a tuner right now with damn near no mods. ima look into underdrive pulleys since that seems to be the easiest to do.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Tuesday at 10:55 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 1:54 PM
limp
  • Gulftown980x
  • Jul 29, 2026
squeak93
