cam timing
  • Thread starter Thread starter 93gt1217
  • Start date Start date Apr 7, 2005
9
93gt1217
18
  • Apr 7, 2005
i just bought a trick flow stage 1 cam... should i just set the cam timing straigt up?
R
Ray@VSK
355
  • Apr 7, 2005
Just about any cam you buy already comes with a few degrees of advance already ground into them & do not need to be degreed, so yes straight up should be fine though I'm not positive about that cam but if you have a degree kit I would check it, if not you should be fine straight up..
bullitstang1313
713
Indianapolis / Columbus, Indiana
Apr 7, 2005
  • Apr 7, 2005
I'd play with it a little before deciding. I would set it at stock first and then advance it slightly. Usually advancing the timing will free up extra power. I set mine at 14-16 degrees BTDC.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
