Cam
You have the advantage in this case since the SD is a batch fire system. That means you have 2 banks of 4 injectors that "fire" or inject fuel at the same time. Mass Air injectors fire individually based on the firing order. It is much more difficult to use a 302 firing order cam with that type of injection.
Plenty of engines have been built using a flat tappet cam with SD. A few people have reported idle problems but more than likely they had other issues that were causing their idle problems.
