  • SN95 4.6L Mustang Tech
Cams+NPI Heads?
  • Thread starter Thread starter SRT Handz
  • Start date Start date Mar 26, 2009
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Mar 26, 2009
  • Mar 26, 2009
What cams will work with NPI heads and NPI Pistons?
Can we get a list Going?
Discuss.....
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Mar 26, 2009
  • Mar 26, 2009
im running powerheads regrinds, 540/540 lift, 225/230 dur @ .50, 112lsa, with almost flat top pistons and i have no ptv problems at all.........
sneaky98gt
2,387
144
114
NC State University
Mar 26, 2009
  • Mar 26, 2009
I just bought a set of Comp XE268h cams. The specs:
Description: SOHC 2 VALVE- Mild street performance, 3.23-3.55 gears required. Noticeable idle. Tune required.
Model number: COMP102200
Application: 1996-1998 Mustang GT, non-P.I. headed vehicles
RPM range: 1600-5600
Cam grind number: XE268H
Advertised Intake Duration: 268
Advertised Exhaust Duration: 274
Intake Duration at .50": 230
Exhaust Duration at .50": 236
Intake Valve Lift: .500
Exhaust Valve Lift: .500
Lobe Separation Angle: 114 degrees
I'll hopefully be getting them in sometime within the next month. I'll let y'all know how the install goes/the dyno results.
I've heard different things about these cams concerning springs. Are they required? Seems like to me that because they are still the stock .500 lift, and because I won't be turning much more than 5800ish rpm, the stock springs would be fine. But IDK. I haven't really got a definite answer. I was hoping to avoid them for now, but if I have to, then I'll just do it. Thanks for the help
-Will
98COBRA281
1,348
30
59
Mar 26, 2009
  • Mar 26, 2009
i upgaded to comp beehives, but i also rev to about 6300, and hoping to rev even higher on the bottle................
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
J
Timing cover for npi 4.6
  • jay99914
  • Oct 26, 2024
SN95 4.6L Mustang Tech Oct 28, 2024
jay99914
J
J
Cam for 1989 2.3 4 plug
  • Jaycee1964
  • Dec 12, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Dec 14, 2025
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
