  • SN95 4.6L Mustang Tech
cams
  • Thread starter Thread starter ls1beater4eva
  • Start date Start date Mar 26, 2008
ls1beater4eva
334
mooresville
Mar 26, 2008
  • Mar 26, 2008
ok well i am doing some research on this a friend of mine has a 04 gt 5spd 355 gears, well we are talking about putting cams in his car he has just a tbody headers and plenum, he is wanting to put some stage 3 crowers in with there valvesprings and a 125 shot does anybody know about what kind of hp this should make?
Green&GoldGT
302
Virginia
Mar 26, 2008
  • Mar 26, 2008
That is alot of cam for a stock engine. Low end power will suffer alot and there is more than likely going to be piston to valve issues. Big cams are pointless if the heads can't flow to match the cam. 3.55 gear is way too low for even a "stage 2" cam. Other mods are needed to support cams like better flowing intake and a dyno tune is required.
Go with cams that will benefit the engine and not big cams that will kill low end power for a few more hp up top. Hope this helps.
chrissaleen
77
Myrtle Beach, SC
Mar 26, 2008
  • Mar 26, 2008
+1!!
R
rugster
156
  • Mar 27, 2008
gonna need at least a 4.10 to pull those cams into the powerband.
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 27, 2008
  • Mar 27, 2008
stage 3 crowers are like stage 2.5 comps or VT's. What's with all the stage II/III cam threads where people just through them on on a whim?
Green&GoldGT
302
Virginia
Mar 27, 2008
  • Mar 27, 2008
crower stage 3's are .590 gross lift intake and .601 gross lift exhaust plus added duration. That's alot of cam in my opinion, and the "supercharged stage 3" is even bigger. Compare those to Cushman's and you will be surprised. Most modular experts will tell you bigger is not always better when it comes to the 2v modular.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Mar 27, 2008
  • Mar 27, 2008
Maybe they have been reading a lot of 4v threads. It seems pretty common with the 4v guys to throw in a set of stage 3 cams and their stock or lightly modified engines pick up good power from them. However on a 2v GT with stock heads a stage 3 cam is just wasting money. Stage 2 is more than enough.
Bill
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 27, 2008
  • Mar 27, 2008
Bill
Agreed
Smokeurhonda
457
Maryland
Mar 27, 2008
  • Mar 27, 2008
Bill
Tell your buddy to stick with stage 2's and get some gear in the car.
Black_GT_02
Ohio
Mar 27, 2008
#10
  • Mar 27, 2008
  • #10
Stage 1 and you wont have to worry about anything else
J
Jim@CMS
23
#11
  • Mar 28, 2008
  • #11
That cam is too big unless you plan on alot more mods down the road. Tone it down in cam choice is my opinion. In camshafts, sometimes less is more. It's all about area under the curve and useable RPM.
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 28, 2008
#12
  • Mar 28, 2008
  • #12
but III is more than II, it must be best for my set-up!
Smokeurhonda
457
Maryland
Mar 29, 2008
#13
  • Mar 29, 2008
  • #13
SonicStangGT
146
King, North Carolina
Mar 30, 2008
#14
  • Mar 30, 2008
  • #14
Yeah, there right. I went out and bought comp stage 3's and what a mess. I have piston to valve issues because of the new duration and lift. Know my motor is out and having to port heads, flycut pistons and put back in because I went to big. More money than I wanted to spend. I bought the 278's for the rough idle, not knowing what I was in for. So if hes not wanting to go inside, go with stage 1 or 2s. Also needs 4.10's, my opinion.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 30, 2008
#15
  • Mar 30, 2008
  • #15
I agree with those who said the Stage II's would probably be the best bet. I cannot stress enough how important it is to get the rear end gears changed to match the cams type you want to use. You really should get the 4.10's. It will be worth every penny. In fact, if you have to make a decision between gears and cams, I'd go with the gears first.
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 30, 2008
#16
  • Mar 30, 2008
  • #16
even with stage II's stock heads and intake manifold don't really allow them to breath up top, and you lose more low end tq. But it's still a great option, especially over stage III's
scupking
1,186
Enfield, CT
Mar 30, 2008
#17
  • Mar 30, 2008
  • #17
Get stage ones or custom blower cams from MPH. I heard they are like a stage 1.5.
blueblazes
76
#18
  • Mar 31, 2008
  • #18
give this guy a ring www.crpautoandfab.com hes a big modular guy and can get you some custom ground cams for good prices and does installs and all. Hes done quite a few and gets some damn good power out of 2v gt's.
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
J
Switched to e85 on the 3v and now it won't run right.
  • jcowdough
  • Aug 24, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 24, 2025
