Camshaft Thrust plate
  • Thread starter Thread starter mustangboy67
  • Start date Start date Sep 4, 2009
M
mustangboy67
  • Sep 4, 2009
I have a 87 mustang motor with the stock 302 HO camshaft that I put In my 67. I lost the original camshaft thrust plate and got a new one and put it in. Well now that the motor is in the car you can hear the timing gear rubbing against the thrust plate and you can see the wear marks on the plate.
I was wondering if there was a difference in thickness between a roller and non roller thrust plate because the one I have may be for an older 302. Also there may be a spacer a may be missing and could that be why it is rubbing?
O
oh9mustang
Banned
Jul 27, 2008
138
  • Sep 5, 2009
As far as I know there is only one thickness of the thrust plate, Maybe a marine version might be different, I would look at the Fuel pump eccentric or the cam gear.
The only way a cam gear could hit the thrust plate is if you had the gear on backwards. The cam gear has a cast in spacer/washer that keeps the gear away from the thrust plate.
D
D.Hearne
11,730
south louisiana
Sep 5, 2009
  • Sep 5, 2009
You need a roller cam gear thrust plate for a roller cam. I had the same problem once in using a non roller thrust plate. The roller thrust plate is hardened to better match the steel roller cam.
D
please help
  • dstuart
  • Sep 26, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 27, 2025
P
Powered by Ford
  • Pappibri
  • Aug 16, 2025
  • Other Auto Tech
Other Auto Tech Aug 16, 2025
D
Pressure plate problems
  • david66
  • Feb 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 27, 2025
Realmongo
D
New Guy In Ga.
  • Driven65
  • Oct 20, 2025
  • The Welcome Wagon
The Welcome Wagon Nov 11, 2025
Driven65
D
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
