Can A Aod Take It??
  • Thread starter Thread starter rod196202
  • Start date Start date Aug 29, 2005
R
rod196202
44
  • Aug 29, 2005
I have 93 vert. with 91,000 miles its stock with most the bolt ons plus lowering springs koni 5 ways new sway bars this and that no real h/p mods yet but comming soon... I have 410s with stock aod i want to put a trsnsgo shift kit in and was told the input shaft breaks with a stiff shift is their truth to this r what i was told i need to change the input shaft if i want to instal the shift kit??? thanks for any help....
M
macx
228
SE Missouri near Cape Girardeau
Aug 29, 2005
  • Aug 29, 2005
Yeah, much of a shock load on that stock input shaft reportedly breaks or twists it.
I did a LOT of research on what to do with AODs, here's some info on them
http://www.lincolnsonline.com/article111.html
Then after fighting unsuccessfully with getting the shift points anywhere near where I'd like, I dug more deeply into a 4R70W swap - with results per this link
(I've got my trans for $200, going to rebuild it with oem frictions etc, found a source for a good moderate stall converter for $200, and after researching wiring in a 94/95 AOD/E ecu to run either the whole shebang or just the trans, have come back to deciding the Baumann is the best setup esp for someone who doesn't have ready and repeated access to tuning equipment to dial in the trans - and tuning devices like the tweecer reportedly only address a few of the trans parameters, and the trans is harder to tune thru a stock ecu than the engine, and it's relatively easy with the Baumann control -
http://www.lincolnsonline.com/article80.html
Everything considered, I think the 4R swap wouldn't be much diff in cost than a
real AOD build, and then the shift points are infinitely tuneable and there's no lockup in 3rd. PLUS you've got heavier duty internals like the output shaft that can NOT be put into an AOD, AND there's no spaghetti input shaft to worry aobut.
R
rod196202
44
  • Aug 29, 2005
so how did you beef up your aod ?
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
